08 de Abril de 2026, 14:43 *
Autor Tema: Franco Kernel Manager v7.0  (Leído 48 veces)
« : 30 de Noviembre de 2025, 10:20 »
Free Download Franco Kernel Manager v7.0 | Android | Root - for almost all functions
Franco Kernel Manager it's a complete toolbox for all devices with a rich feature set aimed for ease of use to supercharge your kernel! From the less knowledgeable, to the most expert user, it combines everything you need to manage, tweak and empower your device.
You want more performance? Check.
You want to boost your battery life? Check.
You want to flash mods without having to use a custom recovery? Check.
Compared to other apps Franco Kernel Manager provides a significantly better experience with features tailored just for you.
Features
- Battery Monitor notification with detailed information about your power consumption during active and idle periods, charging time estimation, charging amps/watts & more;
- Detailed battery stats with information about power consumption in mAh of each component (WiFi, screen, signal, idle, etc) and tons more;
- Build.prop editor;
- Auto-flash kernels, Magisk modules and basically any flashable zips without having to visit a custom recovery;
- Powerful battery saving tips as simple as touching a button;
- Display color temperature presets and support for KLapse;
- Support for Adreno Idler, GPU boost, Adreno, Exynos and Kirin GPUs;
- High Brightness Mode (hbm) available for supported devices (Pixel 3 and 4 for example) & automatic toggle based on the ambient light sensor;
- CPU freqs, governor, support for multi-clusters, GPU freqs, stune, CPU-Boost, CPU Input-boost, governor profiles, governor tunables & more;
- Backup & Restore kernels on the fly with just a tap of a button;
- A kernel logger viewer for developers;
- Custom kernel settings such as: IO scheduler, IO scheduler tuning, wakelocks, lowmemorykiller minfree, KSM, ZRAM, memory stuff, entropy, flar2 wake gestures, scheduler and you can add your own custom tunables too;
- Create Per-app profiles and use different settings for your most used apps. For example you may want max CPU frequency when gaming, but low frequency when reading an e-book. You can also choose whether for Wi-Fi to be on/off, if you desire you toggle Android Battery Saver, specify what type of Location Mode you want to use for that specific app, etc;
- System Health with a beautiful UI, useful real-time CPU/GPU/RAM/ZRAM/DDR BUS/IO/THERMAL ZONES/WAKELOCKS usage and comprehensive CPU frequencies usage with support for clustered devices;
- Display and sound control
- Automatic Night Shift to tint your display in orange/red easing your eyes during the night;
- CPU temperature in the notification bar for devices that export the sensor data;
- Scripts manager allows you to create your own shell scripts within the app and pin as Quick Tiles;
- Light and Dark themes compatible with the latest Android™ version;
- Backup & restore application settings;
Franco Kernel Manager works for ALL devices and kernels.
You need to be ROOTED for all features besides Battery Monitor which works rootless.
Requirements: Android 8.0+
https://play.google.com/store/apps/details?id=com.franco.kernel&hl=en
m0t0d.Franco.Kernel.Manager.v7.0.apk.html
