Free Download WnSoft PTE AV Studio Pro 11.0.20 Build 1 (x64) Multilingual Portable Fast Links | 78.5 MbPTE AV Studio 10 offers you full creative control for your projects. Use the timeline view for perfect synchronization of slides with audio clips on multiple tracks. Powerful keyframe animations with effects. More than 125 templates/styles of animations will help you to easily create your slideshow.
Pan, Zoom, Rotate, 3D
Adjust pan, zoom, rotate, 3D transformations. Control opacity, blur, unsharp mask, and color effects.
Nested Animation
Create complex parent-child animation of objects.
Images and Video Clips
Mix images and video clips together on the screen.
Timeline View
Add and view multiple audio tracks which may be played simultaneously. Synchronize slides with audio clips on the timeline using time points. Link audio clips with slides.
Audio Editor
Envelope tool (keypoint control of sound volume). Edit audio clips: fade in/out, start time, duration, cross-fading.
Objects
Add images, video clips, text captions, masks, interactive buttons and more.
Keyframe Animations
Keyframes work like waypoints. Add first keyframe and adjust position and size of an object. Add last keyframe and adjust the final position of an object and its parameters. PTE AV Studio will animate the object between these keyframes using pan, zoom, rotate etc.
Color Adjustments
Adjust the brightness, contrast, levels, hue, saturation of an image/video. Apply a sepia effect and other color filters. Support of color profiles.
Image Adjustments
Crop images and videos, add beautiful white frame and drop shadow. Apply dynamic blur effect. Use zoom in a frame. Apply masking effect.
Color Management
Support of Adobe RGB monitors in preview and executable shows.
Operating System:Windows 7, Windows 8, Windows 10, Windows 11 (Only 64-bit)
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgator0x6dp.WnSoft.PTE.AV.Studio.Pro.11.0.20.Build.1.x64.Multilingual.Portable.rar.htmlFileaxa0x6dp.WnSoft.PTE.AV.Studio.Pro.11.0.20.Build.1.x64.Multilingual.Portable.rarDDownload0x6dp.WnSoft.PTE.AV.Studio.Pro.11.0.20.Build.1.x64.Multilingual.Portable.rarFreeDL0x6dp.WnSoft.PTE.AV.Studio.Pro.11.0.20.Build.1.x64.Multilingual.Portable.rar.htmlAlfaFilehttps://alfafile.net/file/AFSPr/0x6dp.WnSoft.PTE.AV.Studio.Pro.11.0.20.Build.1.x64.Multilingual.Portable.rarLinks are Interchangeable - No Password - Single Extraction
