05 de Abril de 2026, 01:43 *
Autor Tema: ZW3D 2026 SP1 Multilingual (x64)  (Leído 65 veces)
« : 02 de Diciembre de 2025, 05:31 »
Free Download ZW3D 2026 SP1 (x64) Multilingual Fast Links | 4 GB
ZWSOFT, an innovative supplier of CAD solutions to the AEC and MCAD industries, announces that the official version of the brand's flagship solution, ZWCAD is now available. ZWCAD Official is powered by a brand-new hybrid technology, and it couples familiar interface with 64bit system support so users can do even more, faster, easier and better.
Intelligent 2-Axis Milling
Hole & 2-Axis Tactics can help generate manufacturable toolpaths automatically, cutting programming time by 70%.
Productive 3-Axis Milling
- More than 40 types of machining operations are available to facilitate efficient machining, so that you can deal with all kinds of manufacturing work at ease.
- No matter on Nurbs or STL geometry, desired toolpaths, or even undercut toolpaths can be easily generated.
Advanced 4-Axis and 5-Axis Milling
- 5-axis milling provides a complete solution for indexing and 4 to 5-axis machining, and it's also able to work with STL file.
- Comprehensive functions, like Swarf, Drive Curve, Drive Surface, Flow Cut, Side Cut and Point Control are available to extend machining capabilities for different scenarios.
Reliable Verification and Simulation
Numerous verification and simulation tools are delivered to ensure feasible, reliable and safe machining.
- Solid Verify can be used to simulate the actual machining process and analyze the excess materials, realizing reliable and efficient machining.
- Analysis functions help detect collisions and gouges between tools and stocks, tables, clamps, etc.
- The accurate calculation of the minimum tool hang length ensures the safety of machining.
Easy-to-Customize Post Processor
ZW3D Post offers advanced post-processing capabilities to convert cutter location data (APT-CL) into machine-specific codes (GM codes) required by CNC machines. All classes of 3 to 5-axis milling machines are supported.
System Requiremens:
OS: Windows 7 SP1/ Windows 10, and more.
CPU: Intel Core 2 Duo @2GHz or above, or equivalent AMD® processo
RAM: Recommended configuration: 4G or above
Video:
OpenGL 3.1 or above
nVIDIA Quadro FX 580 @ 512MB or above, or equivalent AMD Graphic card
Minimum configuration: 1024 x 768 VGA with True Color
Recommended configuration: 1280 x 1024 VGA with True Color or above
https://www.zwsoft.com/
ic9kd.ZW3D.2026.SP1.x64.Multilingual.part1.rar.html
ic9kd.ZW3D.2026.SP1.x64.Multilingual.part2.rar.html
ic9kd.ZW3D.2026.SP1.x64.Multilingual.part3.rar.html
ic9kd.ZW3D.2026.SP1.x64.Multilingual.part4.rar.html
ic9kd.ZW3D.2026.SP1.x64.Multilingual.part5.rar.html
Fileaxa
AlfaFile
https://alfafile.net/file/AFSPm/ic9kd.ZW3D.2026.SP1.x64.Multilingual.part1.rar
https://alfafile.net/file/AFSP7/ic9kd.ZW3D.2026.SP1.x64.Multilingual.part2.rar
https://alfafile.net/file/AFSPE/ic9kd.ZW3D.2026.SP1.x64.Multilingual.part3.rar
https://alfafile.net/file/AFSPy/ic9kd.ZW3D.2026.SP1.x64.Multilingual.part4.rar
https://alfafile.net/file/AFSPp/ic9kd.ZW3D.2026.SP1.x64.Multilingual.part5.rar
