Free Download Node Mill LensNode 1.0.16 (x64) | 94.6 MbFast, fun and accurate simulation of real-world lens characteristics. Fully GPU powered, it's simple to use and quick to apply. Get creative, get technical, and tinker as much as you want.
Real Lenses
Simulate the look of well-known lenses using presets created with real world data.
Access an expanding library of unique lens profiles and enhance your footage.
Real Lenses
Overdrive
With a single slider, LensNode allows you to exaggerate the effects of a lens profile to quickly and easily create interesting effects. All parameters can be animated, and individual characteristics are tuneable to taste.
Accurately Profiled Features
The presets in LensNode are based on a series of data captures in different conditions, dialled in with a high attention to detail.
Coma
Comatic Aberration is one of the most difficult effects to recreate without LensNode, and one of the most critical to the look of many vintage lenses. Easy to mistake for bloom or softness, the unique shape, hue, and direction of this aberration are the keys to great lens simulation.
Distortion
Lens distortion is the first touchstone when simulating lenses in visual effects, and accurate distortions are built into the foundation of LensNode. The distortion, like everything else in LensNode, can be animated, and it's automatically scaled to fill the frame.
Bloom
The high performance, accurate, exponential falloff bloom in LensNode brings unmistakable softness and contrast to the image. Captured and profiled at 14-bit, this bloom rivals the best diffusion filter plugins on the market.
Chromatic Aberration
Lenses split unique wavelengths of light depending on their shape and material. LensNode creates hue-accurate aberration with a smooth falloff to remain true to the original character of each lens.
Bokeh Blur
LensNode's modelling not only extends to capturing the unique bokeh shape of each lens for edge blur and softening, but rotates it before convolution, making it one of the most accurate lens blurs available. This makes LensNode capable of swirly bokeh too, including for lenses that don't naturally exhibit this feature.
Vignette & Color Cast
Vignettes are captured straight from the real lens, and normalized to the exposure of your shot. LensNode vignettes also include subtle hue shifts towards the edge of frame, just like a real lens. Color casting is captured in 14-bit raw color, and can be set to affect the whole image, or just the corners.
Fringing
LensNode has the ability to emulate the fringing on high contrast areas that some lenses exhibit. The combination of fringing, coma and chromatic aberration are the main characteristics that give a lens its overall texture. LensNode's fringing can also vary in hue, saturation and lightness across the image from the center to the edges.
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgator6am2f.Node.Mill.LensNode.1.0.16.x64.rar.htmlDDownload6am2f.Node.Mill.LensNode.1.0.16.x64.rarFreeDL6am2f.Node.Mill.LensNode.1.0.16.x64.rar.htmlLinks are Interchangeable - No Password - Single Extraction
