05 de Abril de 2026, 18:22 *
Autor Tema: KS DB Merge Tools for Oracle 1.14.0  (Leído 49 veces)
« : 07 de Diciembre de 2025, 15:57 »
Free Download KS DB Merge Tools for Oracle 1.14.0 | 26.2 Mb
If Oracle is your database management tool of choice, then an application such as KS DB Merge Tools for Oracle is surely of great help. This software utility is designed for database comparison and synchronization, allowing you to compare data and schemas inside two Oracle databases and merge any changes that might occur.
To make it easier for you to spot differences, KS DB Merge Tools for Oracle displays data on two panels, each allowing a direct connection to an Oracle database. A few details are required to help you get started: the server's name and the port number, as well as the connection credentials. The connection can be tested to see if everything works as it should.
There are other connection options besides entering the credentials manually: KS DB Merge Tools for Oracle can use connection strings for each database.
KS DB Merge Tools for Oracle compares the database schemas and the programming objects. In other words, you can use it to compare tables, columns and constraints, as well as views, procedures and functions in the Oracle databases. Moreover, it can spot differences between the two database schemas and sequences.
Filters can be easily applied to reveal changes since the application was used, whether we are talking about recent changes, new ones or both. Data can be compared per table or per view. KS DB Merge Tools for Oracle is able to spot differences across multiple tables and views. It is possible to merge changes in both directions
It is always easier to compare two databases when you have their contents displayed in front of you, side by side. KS DB Merge Tools for Oracle allows you to closely compare two Oracle databases and merge differences both ways without a lot of hassle. This allows you to keep your Oracle databases up-to-date.
https://ksdbmerge.tools/oracle-diff-merge-overview.html
22o50.KS.DB.Merge.Tools.for.Oracle.1.14.0.7z.html
