07 de Abril de 2026, 11:26 *
Autor Tema: Autodesk Revit 2025.4.4 with Updated Extensions Win x64  (Leído 74 veces)
« : 08 de Diciembre de 2025, 04:24 »
Free Download Autodesk Revit 2025.4.4 with Updated Extensions | 7.6 Gb
Languages Supported *: English US, English UK, Deutsch, Français, Español, Brazilian Português,
Italiano, Русский, Polski, Čeština, Simplified 中文, Traditional 中文, 日本語, 한국어
Autodesk has releasedREVIT 2025.4.4is a powerful software program that provides a new way for architects, engineers and construction professionals to design, document and collaborate on building projects.
Autodesk Revit 2025 offers new capabilities and enhancements for site design and toposolids, upgrades for modeling and documenting concrete and steel design, in addition to new features for sustainability and carbon analysis, structural analysis, and MEP analysis and fabrication. There are many community ideas realized in Revit 2025, among them sheet collections which benefit efficiency for everyone documenting in Revit, single element and empty arrays for modeling families, and wall joins which improve the experience of placing and manipulating walls, making it more predictable and less prone to error. There's also more connectivity to Autodesk Docs, improvements for openBIM workflows and data exchange, and other project management upgrades and schema improvements.
What's New in Revit 2025
Dynamo Updates 3.3 (What's New in 2025.4)
Dynamo 3.3 introduces an updated TuneUp package for graph performance monitoring, improvements to Package Manager, an option to bulk edit the engine of Python nodes, and more.
Highlights include:
-Package Manager improvements:Dynamo's Package Manager allows you to install and upload packages that extend Dynamo's functionality. Improvements include a more reliable Retain Folder Structure option for package authors, package size information in version details, search by package author, and more. You can access Package Manager from the top navigation menu in Dynamo under Packages Package Manager.
-Updated TuneUp package for graph performance monitoring:The TuneUp extension provides information about node execution order and duration. Updates include the option to show grouped nodes together under a colored bar, a refreshed look and feel, and renamed nodes distinguished with a blue dot.
-Easily change the Python engine of Python nodes, DYFs, and custom nodes:To change the Python engine for all applicable nodes in the current graph, in the top menu go to Edit Set Python Engine, then select your desired Python engine. To change the engine for selected nodes only, right click to open the context menu Python Engine Version select your desired engine.
-Better icon quality:All out-of-the-box nodes and tooltips for warning, error, and info states have updated icons with higher resolution, resulting in clear and crisp visuals.
Admin Add-Ins Manager (What's New in 2025.4)
BIM Managers and System Administrators can now manage Revit Add-Ins Manager settings on users' machines.
Download and install (Admin) Add-Ins Manager for Revit tool, and use it to configure settings for each add-on installed on the same machine (Admin) Add-Ins Manager runs on. The (Admin) Add-Ins Manager has a global option to Disable the loading of any third-party add-on.
2025.4.4 Update - Release Date: December 1, 2025
The Revit 2025 updates are cumulative and include all changes from previously released Revit 2025 updates.
After this update is applied successfully, the build number specified on the Help > About dialog will be:
-    25.4.41.14
-    20251111_1515(x64)
-    2025.4.4
Software embedded in the update executable:
ADP Desktop SDK - version 5.5.54.0
Generative Design for Revit - version 25.5.6.0
Personal Accelerator for Revit 2025 - version 24.4.40.0
Addins Manager for Revit 2025 - version 25.4.41.14
Cloud Models for Revit 2025 - version 25.4.41.14
Core Content for Revit 2025 - version 25.4.41.14
Core Package - Component for Revit 2025 - version 25.4.41.14
Core Package - ATF for Revit 2025 - version 25.4.41.14
Core Package - Cloud for Revit 2025 - version 25.4.41.14
Core Package - CefSharp for Revit 2025 - version 25.4.41.14
Dynamo Core for Revit 2025 - version 25.4.41.14
Dynamo Docs - version 25.4.41.14
Dynamo Samples - version 25.4.41.14
Core Package - RVT Component for Revit 2025 - version 25.4.41.14
TwinMotion Package Component for Revit 2025 - version 25.4.41.14
Unit Schemas for Revit 2025 - version 25.4.41.14
Product Feedback for Revit 2025 - version 25.4.41.14
Carbon Insights for Revit 2025 - version 25.4.41.14
Important Notes - Installation
The Revit 2025.4.4 Update does not support uninstall. Once the Revit 2025.4.4 Update is applied, Revit 2025 cannot be reverted to its pre-update state.
General
- Addressed potential security vulnerabilities.
- Addressed RFA File Parsing Vulnerability in Autodesk Revit.More details.
Assemblies
- Fixed an issue in which models cannot be upgraded with inconsistent centerline assemblies.
Export PDF
- Fixed a truncated string issue in background PDF export blocking dialog.
- Improved stability when selecting views and sheets to export to PDF.
File Open/Save
- Fixed an issue that prevented cloud models from Desktop Connector to be loaded as groups into models.
IFC
- Fixed an issue where some rooms were not respecting 3D bounding elements on export to IFC.
Materials
- Fixed an issue where the paths of material textures stored on Autodesk Docs would break after multiple users had worked on the same material through worksharing.
Pressure Loss Calculations
- Fixed a stability issue where the integer-type formula parameters based on duct or pipe family connector flow might throw internal exceptions.
Print
- Fixed an issue where Raster Images in background behind a floor would incorrectly show through non-masking filled regions in vector print and PDF Export and not match the screen.
- Fixed an issue where a background raster image would incorrectly show through the model in areas with overlapping elements including a sloped floor when vector exporting and printing to PDF.
Revit Cloud Model (workshared)
- Improved resiliency for cloud worksharing analytics requests.
Stairs
- Improved stability of some models with stairs.
Revitis a powerful Building Information Modelling (BIM) tool designed to help stakeholders design, visualise, and construct buildings more efficiently than ever before. But Revit is way more than just a digital drafting tool. In fact, Revit makes it easy for everyone to work together, makes workflows more efficient, and lets you get the most out of BIM. These are some of the reasons that BIM has become an indispensable tool in the AEC (architecture, engineering and construction) industry as it brings in many advantages and applications enhancing the design and construction process.
What's new in Revit 2025
Autodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
Owner:Autodesk
Product Name:REVIT
Version:2025.4.4 with Updated Extensions *
Supported Architectures:x64
Website Home Page :www.autodesk.com
Languages Supported:multilanguage *
System Requirements:Windows **
Software Prerequisites:pre-installed Autodesk REVIT 2025.0 and above
*NOTE: For each of the supported languages, the Revit software contains translations for the user interface. Revit does not use language packs. Instead, the base language for the software is determined as follows:
-When installing Revit on a single computer:The language (and locale) for the software is based on the computer's regional settings specified for the operating system.
-When creating a Custom Install:The language (and locale) for the deployment image is based on the regional settings specified for the operating system of the computer used to create the deployment.
Languages for Revit content
In a default Revit installation essential language content packs for the 14 supported languages in Revit will be installed. Essential language content is option within Custom Install workflows.
Revit_2025_4_4.exe
Revit Interoperability 2025.4.4 Update (Revit Core Engine 2025)
Autodesk Data Exchange Connector for Revit 2025 v1.9.0
Autodesk Data Exchange Connector for Rhino 7 v2.1.8
Autodesk Data Exchange Connector for Rhino 8 v2.1.8
Autodesk Data Exchange Connector for Tekla 2023 v1.3.0
Autodesk Data Exchange Connector for Tekla 2024 v1.3.0
Autodesk Data Exchange Connector for Tekla 2025 v1.3.0
IFC v25.4.4 for Revit 2025
Interoperability Tools Model Checker Configurator v10.0.9.4966 for Revit 2025 and Validation Tool 2025
Issues Addin v8.0.1 for Revit 2025
MEP Content Editor Sync v5.0.1
AutodeskRevit202544withUpdatedExtensions.html
Fileaxa
zjoso.Autodesk-Revit-2025-4-4-with-Updated-Extensions.part1.rar
zjoso.Autodesk-Revit-2025-4-4-with-Updated-Extensions.part2.rar
zjoso.Autodesk-Revit-2025-4-4-with-Updated-Extensions.part3.rar
zjoso.Autodesk-Revit-2025-4-4-with-Updated-Extensions.part1.rar.html
zjoso.Autodesk-Revit-2025-4-4-with-Updated-Extensions.part2.rar.html
zjoso.Autodesk-Revit-2025-4-4-with-Updated-Extensions.part3.rar.html
AlfaFile
https://alfafile.net/file/AFFKw/zjoso.Autodesk-Revit-2025-4-4-with-Updated-Extensions.part1(1).rar
https://alfafile.net/file/AFF5v/zjoso.Autodesk-Revit-2025-4-4-with-Updated-Extensions.part2.rar
https://alfafile.net/file/AFF5C/zjoso.Autodesk-Revit-2025-4-4-with-Updated-Extensions.part3.rar
