05 de Abril de 2026, 23:13 *
Autor Tema: Imaginando BAM v1.5.4  (Leído 44 veces)
« : 12 de Diciembre de 2025, 11:29 »
Free Download Imaginando BAM v1.5.4 | 344.2 Mb
BAM - Beat Maker & Music Maker gives you everything you need to bring your musical ideas to life.
Whether you want to make beats or make music, BAM - Beat Maker & Music Maker is perfect for beginners and masters alike. If you are new to beat making, BAM is the ideal way to learn how to make beats and create music; the easy-to-use interface means you can become a beat maker in minutes!
BAM comes loaded with a variety of fantastic built in synthesis engines and effects: oscillator synthesizer, sampler, drum synthesizer, analog bass synthesizer, analog emulation of drum elements, FX: filter, EQ, delay, chorus, compressor, saturator, etc.
Plus the included sample library is a huge sonic smorgasbord of sounds, easily accessible via the built in sample manager and recorder.
Features
16 rack-style tracks plus Master and 2 send channels
AUv3 plugin support, including MIDI effects
Full mixer with volume, pan, mute, solo, arm controls
Built-in synthesis engines: Oscillator synth, Drum synth, sampler, classic acid bass synth
Built in effects: Filter, 3-band EQ, parametric EQ, delay, chorus, compressor, reverb, phaser, saturator, bit reduction, stereo enhancer
MIDI clip piano roll editor
Step sequencer with up to 256 steps per clip
Clip based parameter modulation editor
Track level trigger options plus LFO and EG modulators
Matrix MIDI clip and scene launcher with extensive follow action options
Sample library including over 1000 drum and percussive samples, plus melodic timbres
Step-by-step beat making
Step up your rhythm game and make beats in minutes with the BAM - Beat Maker & Music Maker step sequencer. Turn your ideas into drum loops in seconds, with the easy-to-use up to 256 step sequencer interface. Easily visualize multiple tracks with different clip lengths simultaneously, as each track's playbar indicator moves independently in relation to others.
Make beats, make music, make tracks
BAM is not just a beat maker of course, it's a beat maker and a music maker. Get musical with BAM's range of built-in synthesis engines, including an amazing oldskool acid bass synth that is sure to take you to a higher state of consciousness. (wink-wink)
Fantastic FX, just a finger tap away
BAM's rack based processing features a range of high-quality built-in effects: Filter, 3-band EQ, parametric EQ, delay, chorus, compressor, reverb, BURNER (the fiery saturator), bit reduction, and stereo enhancer. Chain up to five of these effects on each track, and on BAM's two available send channels as well!
Use your favorite iOS AUv3 plugins too
You can of course load your favorite AUv3 instruments, effects and plugins alongside BAM's built-in selection, and mix it up however you want (iOS version only). Each track has a dedicated AUv3 MIDI Effect plugin slot in addition to five audio processing effects slots.
Automations made easy
Make beats with movement using easy parameter lock style, step-based automation. Choose any parameter and mix it up on the fly, for real-time hands on control of the beat maker process for endless creative possibilities. Each track also includes trigger options and two modulator slots for Envelope Generator and LFO based modulators.
Powerful clip launcher for live performance and arrangement
Go from beat maker to live performer in an instant, with the versatile matrix view. A scrollable grid of clips for all 16 tracks. Build loops by adding, duplicating and editing scenes, and arrange full tracks with extensive follow action functionality. Perform and remix your music live with individual clip and scene launching.
Mixing up the beat maker scene
Much more than just a beat maker, BAM's built-in mixer provides control of your mix, with up to 16 tracks, 2 sends and a Master channel. Adjust levels, mute, solo and arm tracks for recording and more, BAM is an easy to use, feature-packed music maker that is hard to put down.
Sounds and samples sorted
BAM - Beat Maker & Music Maker comes loaded with an extensive and eclectic library of samples and sounds, featuring a mixture of melodic instruments and over 1000 high-quality original acoustic and electronic drum and percussive samples. The combined sample browser, recorder, and selection pool make sample management a breeze.
Composers - take note
BAM - Beat Maker & Music Maker's composer panel features a familiar piano roll interface, designed for both desktop and touch interaction. Whether you want to edit beats or Beethoven, you can do it anywhere with BAM - Beat Maker & Music Maker.
Requirements:
Windows 10 or higher, compatible 64 bit host DAW which supports VST plugin format, plus a minimum of 650 Mb of free disk space to install. Product licence activation requires internet connection.
https://www.imaginando.pt/products/bam-beat-maker-and-music-maker
p33ld.Imaginando.BAM.v1.5.4.rar.html
