07 de Abril de 2026, 06:42 *
Autor Tema: Sonbile Smart Comp 3 v1.0.0  (Leído 55 veces)
« : 12 de Diciembre de 2025, 11:30 »
Free Download Sonbile Smart Comp 3 v1.0.0 | 37 Mb
smart:comp 3 is designed to support your creative intention. This audio compressor plug-in uses intelligent algorithms to translate your signal into an intuitive map of viable compression characteristics. You achieve transparent, musical results faster while keeping your workflow smooth and focused. For granular dynamics shaping, smart:comp 3 provides all common compression controls, advanced Style options, and Spectral Compression.
Intelligent parametrization & Spectral Compression
Semantic approach to dynamic control
Group Mode, zero-latency compression, Spectral Ducking, ...
Features
Up your compression game
Audio compression powered by AI and a semantic approach
Your track knows the way. smart:comp 3 maps it.
What is new in smart:comp 3
* Compression Matrix: Displays a range of compressor settings and allows smooth transitions between different compression characters.
* Compression Scope: Visualizes the viable compression range of the analyzed signal.
* Group Mode: Links multiple plug-in instances for shared control of threshold, ratio, attack, release, and mix. Enables batch adjustments from a single interface.
* Zero-latency Mode: Minimum-phase processing for live use and recording with no delay. Linear-phase mode remains available for mixing and post-production.
* Refined Input Riding: Stabilizes level variations prior to compression.
* Enhanced Style Control: Updated compression engines with defined attack and release behavior and refined saturation characteristics.
Smarter control of complex sessions
Accelerate complex mix workflows and ensure consistent compression across multiple tracks with smart:comp 3's Group Mode. Forget about jumping from instance to instance to tighten drum channels or align the compression of different vocal tracks. smart:comp 3 lets you work on up to 7 tracks simultaneously from a single window. All grouped instances appear in the Compression Matrix and the signal history, where you can batch-edit threshold, ratio, attack, release, and mix. Managing large sessions and improving overall cohesion has never been easier.
Shape your compression down to the smallest detail
Aside from all common compression controls, smart:comp 3 also comes with the Advanced Tabs that provide you with a range of features for fine-tuning and sonic flexibility. Our intelligent compressor offers three Style options - Clean, Smooth and Aggressive - that give you immediate access to well-calibrated compression engines tailored to different creative and technical contexts. An additional, fully tweakable Custom style enables complete control over attack/release shapes and saturation behavior. Our unique technologies Spectral Compression and Spectral Ducking are staples in our intelligent compressor. They make sure that additional compression or ducking only is applied where it is actually needed to maintain natural dynamics and energy in your mix. smart:comp 3 also offers refined Input Riding, Minimum Phase Mode for zero-latency performance, Mid-Side Mode, and much more.
https://www.sonible.com/smartcomp3/
l49zv.Sonbile.Smart.Comp.3.v1.0.0.rar.html
