05 de Abril de 2026, 21:52 *
Autor Tema: progeCAD 2026 Professional 26.0.10.10 (x64)  (Leído 91 veces)
« : 15 de Diciembre de 2025, 20:57 »
Free Download progeCAD 2026 Professional 26.0.10.10 (x64) | 1.4 GB
progeCAD is an AutoCAD® compatible 2D/3D CAD application that works with AutoCAD® DWG files from v. 2.5 to v. 2026 and imports Autodesk Revit®, IFC and SolidWorks files! The best solution for AEC, MCAD and all generic CAD usages. Supports Dynamic Blocks Creation/Editing (Advanced Blocks).
progeCAD sells with perpetual licensing and offers more CAD functions than AutoCAD® LT at a fraction of the cost of AutoCAD®, ArchiCAD® , ZwCAD® , Draftsight®, GstarCAD®, BricsCAD®or Microstation®
SOME REASONS FOR PROGECAD PROFESSIONAL
Perpetual Licensing! No annual fee. You decide when to upgrade
Nothing to learn for an AutoCAD® user
Work natively with DWG! Full compatibility with AutoCAD® without conversion
Import BIM projects and objects (Autodesk Revit® and IFC) and SolidWorks Models
PDFtoDWG (PDF2DWG) conversion included
Dynamic Blocks Insertion/Creation/Editing
RasterDraw plug-in (Raster Design replacement)
Export to Google Earth®
Create architectural layouts in a flash with the AEC parametric plug-in
22.000 blocks ready to use + customizable blocks manager
Surveing, GIS and Civil Features
Import/Export - Rvt, Rfa, IFC, STEP, IGES, SolidWorks, PDF, 3D PDF, DWF, 3DS, DAE, LWO, POV, Maya, OBJ, BMP, JPG, WMF, EMF, SVG
Professional Artisan Render Engine included
PROGECAD ADVANCED FEATURES
PDF Export with Layers - includes PDF/A ISO19005 Standard export
PDF to DWG conversion
Insert BIM models into DWG. IFC and Autodesk Revit® files supported
Exports STEP, IGES, PDF, DWF, 3DS, DAE (Collada), STL, LWO, POV, MA(Maya), OBJ(Wavefront), BMP, JPG, WMF, EMF, SVG
Imports STEP, IGES, IFC, Rvt/Rfa (Revit®), SolidWorks .sldprt part files and .sldasm assembly, ESRI-SHAPE SHP, 3DS, DGN(Microstation), LWO, OBJ, STL, IFC, RGT, DXF, DWF, DWFx
PointCloud import (ReCap® .rcp, .rcs, .pcg, .isd, .xyz, .ply, .las, .laz)
Customizable Toolpalettes for Blocks, Hatches and frequently used Commands
3D Print - STL export for 3D Printer output
iCADLib Blocks Manager. More than 22.000 2D/3D ready-to-use blocks
Direct access to Traceparts, Cadenas and BIM&CO with millions of blocks and BIM objects ready-to-use
Parametric generation and insertion of 2D or 3D mechanical/structural components for construction
ACIS solids
Dynamic blocks - Advanced Blocks (Insertion/Creation/Editing)
3D AEC Architectural - 3D/2D building plugin for architects (Compatible with AutoCAD® Architecture
Quick Calculator - use the calculator with the Properties palette to change the objects's properties.
SuperHatch
Helix and Loft Commands
Multileaders
MAPIMPORT - Geo Data and FDO Import
Inserts geometries from SDF files, SQLite and SHAPE (esri) files, or can use a database server service like WFS
Gradient Hatch
Bitmap/Raster support - Jpeg, TIFF, Png, Gif, ECW, MrSID and Jpeg 2000
Bitmap polygonal clipping
Geolocation with interactive background map from Microsoft Bing
Description Margin Customization - cover the entire sheet area
Digital signatures to .dwg files
Spell-check on the fly
DATALINK - Link a Microsoft Excel spreadsheet to a progeCAD table
XLSIMPORT - Imports directly an .xls or .xlsx file into a new static progeCAD Table.
DATAEXTRACTION create a detailed schedule, a parts list, or a bill of materials
AUTOSEZ - automatic creation of surface profiles (Topographic Sections - AutoCAD Civil 3D Feature)
SLOPE creation of slope patterns
ARX Syntax Compatibility
Block Editor (Compatible with Advanced Blocks/Dynamic Blocks)
Raster Draw - The Raster Design® replacement
Generative AI Drawing Translator - Translate drawings with the power of Translate drawings with the power of artificial intelligence
QRCODE - Create and insert a QRCODE from any text, URL etc.
MAPIINSERT - Insertion of multiple images at the same time
Rubber sheeting - Nonuniform adjustment of images (MAP/GIS)
Google EarthTM Integration
3D PDF Export
Construction Lines
Tables - AutoCAD® like Text in-place editing, numeric Rows, and alphabetical Columns. Cells with Formulas supported.
Color Books - progeCAD supports standard Color Books
AutoCAD® like Sheet Set Manager
Dynamic UCS
Dynamic Input
AEC, Civil, GeoMaps, Mechanical objects support
Flatshot command - Generates an accurate flat view of a 3D model
AREATEXT - Calculate boundary area and place the text with the value in the center of the area.
ARRAYPATH - Place object copies uniformly along a path or a portion of a path
Find and Replace
Express Tools - A complete set of Extra functions for Blocks, Layers, Texts
Annotative Objects
SHEETSET - Sheet Set Manager
Arc Aligned Text
Multigrip Editing
Render engine - progeCAD integrates for free the Artisan Renderer module
Automatic Perspective image correction
QUICK PROPERTIES Palette Rapid access to the most useful object properties
3DConnection SpaceMouse and CADMouse support
eTransmit - Compacting and transmitting DWG files with dependences by email
Eattedit - Advanced Attribute editing
QDIM - Quick dimensioning
3DWALK and 3DFLY - Changes the 3D view in a drawing interactively to create the appearance of walking or flying through the model
Publish (Batch Description)
Raster to Vector converter - Convert your paper drawings to editable DWG files
Cloud - Share files on Cloud - Supports the major cloud services for file sharing and syncing like DropBox, Google Drive and Microsoft One Drive
BetterWMF Integration
https://www.progesoft.com/
gbefc.progeCAD.2026.Professional.26.0.10.10.x64.rar.html
