07 de Abril de 2026, 03:07 *
Autor Tema: Chaos V-Ray 7, Update 2 (7.20.10) for Houdini Win x64  (Leído 75 veces)
« : 16 de Diciembre de 2025, 15:56 »
Free Download Chaos V-Ray 7, Update 2 (7.20.10) for Houdini | 1.1 Gb
Chaoshas releasedV-Ray 7, Update 2 (7.20.10) for Houdini, the latest version of the Houdini edition of the renderer. The update adds a procedural night sky system, "completely re-imagines" the volumetric shader for fire and smoke, and adds support for the AI material generator in Chaos Cosmos
Owner:Chaos Czech a.s.
Product Name:V-Ray 7
Version:Update 2 (7.20.10)
Supported Architectures:x64
Website Home Page :www.chaosgroup.com
Languages Supported:english
System Requirements:Windows *
Software Prerequisites:pre-installed Houdini 21.0.512 or 21.0.440
New procedural night sky
V-Ray 7.2 for Houdini introduces several of the new features recently rolled out in the 3ds Max edition of the renderer, including the new procedural night sky system. Users can generate a night sky matching a specific real-world location, date and time, or adjust the position and brightness of the moon and stars manually.
Access to the AI Material Generator in Chaos Cosmos
Houdini users also get access to the AI Material Generator available in the Chaos Cosmos, the asset library included with all V-Ray subscriptions. It generates a PBR material and texture maps matching a real-world reference photo.
'Re-imagined' Volume Shader for smoke and fire effects
V-Ray 7.2 for Houdini also includes what Chaos describes as a "completely re-imagined" volumetric shader. The only specific change to the Volume Shader mentioned in the release notes is new Blackbody and Artistic emission models, but Chaos's blog post also namechecks "deep output support, volumetric holdouts, and enhanced Light Path Expressions".
Other feature updates
The 3D Gaussian Splatting toolset introduced in V-Ray 7 for Houdini gets the option to clip splats, helping to blend 3DGS scans with conventional 3D assets. Other changes include support for resolution-independent bump mapping in the V-Ray Material, and support for acceleration blur.
Vantage now also available as a Houdini viewport renderer
In related news, Vantage, Chaos's path tracing renderer, often used to explore large V-Ray scenes in real time, is now available as a viewport renderer in Houdini.
V-Ray 7, Update 2 (7.20.10) Official release - Date: Decemder 8, 2025
V-Ray
-    Added Artistic and Blackbody emission models for the V-Ray Volume Shader VOP
-    Added Moon and Stars options on the V-Ray Sun Light for a night sky effect when the sun is below the horizon
-    Added the option to clip Gaussian Splats loaded through the V-Ray Gaussian Splat LOP/SOP node
-    Added resolution-independent bump option on the V-Ray material to aid in cases where the bump appearance differs across various resolutions
-    Added the ability to override the mip-map level of textures in an object's shading graph under the Render Geometry Settings LOP
-    Added support for Acceleration Blur under the Velocity Blur menu
-    Added support for the normals' Cusp Angle property
-    Added support for camera resolution override when using the UV Projection VOP in Perspective mode
Chaos Cosmos
-    Added support for AI-based material generation in the Cosmos browser
Houdini
-    Added support for Chaos Vantage as a Solaris render delegate
-    Added support for MaterialX nodes in Vantage natively
-    Added support for 21.0.512
-    Added support for 21.0.440
-    Added support for 20.5.684
-    Added support for 20.5.654
-    Added support for 20.5.613
Solaris
-    Added initial support for Hydra2
-    Added support for dynamic parameter aliases in Hydra
-    Added a simple version of a custom Deadline submitter, shipped with the V-Ray for Houdini installation
-    Added a new Cubic mode for rendering of splines to improve Feather Procedural results with V-Ray. Further optimized time to first pixel and RAM use
-    Added support for int64 primvars
MaterialX
-    Added support for 1.39
-    Added support for the MtlX Standard Surface VOP's Dispersion parameter
-    Added support for the MtlX Facing Ratio VOP
-    Added support for mixing displacement
Modified Features​
V-Ray
-    Light Path Expressions will now be internally converted to V-Ray Light Selects where possible, to accelerate rendering and aid in setups that utilize V-Ray Light Cache
-    Hair tessellation is now multi-threaded to reduce the time to first pixel
-    The maximum number of V-Ray Light Select AOVs is now increased from 96 to 256
Houdini
-    The V-Ray installer executable will now utilize the HOUDINI_PACKAGE_DIR variable to point to the installation files' location
V-Ray
-    Broken materials in V-Ray standalone with USD 0.25.05
-    Face_mtlIDs attribute is ignored for .vrmesh export
-    Only the first frame is successfully rendered with V-Ray Standalone for a particular VRScene file
-    Crash with Alembic, motion blur, and subdivision in a specific case
-    Possibility to set a pre-scaled vector texture for displacement
-    Inconsistent results with Reflection Glossiness/Roughness parameters on V-Ray GPU and V-Ray CPU.
-    The animated displacement amount does not work in IPR when changing frames
-    Stepped deformation blur with single-file Alembic caches when using more than 2 geometry samples for motion blur
-    Attributes used directly as a bump texture do not work
-    Not all instance data is exported into .vrmesh when doing a V-Ray Proxy export
-    Debug version with better visualization for LPEs
-    Wrong output for Diffuse AOV when using Blend material with multiple Hair materials
-    Investigate artifacts and slower rendering with a particular scene between V-Ray 6.2 and V-Ray 7.0
-    The position of geometry is not updated when Velocity blur/Acceleration blur is enabled
-    Do not display an error dialog when the error code is 0
-    Deprecate the Displacement Shift parameter for V-Ray Decal
-    Material not exported for points
-    Alembic velocity motion blur doesn't match with unpacked geometry
-    No motion blur with alembic files and displacement in the shading graph
-    UV seams with V-Ray Subdivision when underlying mesh has overlapping or non-convex faces
V-Ray Licensing
-    Hang when closing the login dialog in Solaris
-    Using the new named licensing, a GUI license is NOT engaged for Production rendering in 'vanilla' Houdini
-    Python render pick up interface license
Chaos Cloud
-    Fixed an issue causing scene upload to fail due to a version mismatch
Solaris
-    Endless loop when Geographic Position is enabled for the V-Ray Sun
-    The default signature of a parameter is no longer working
-    Pattern ID node is broken
-    Switching on/off Make Instanceable parameter causes the geometry to disappear from the viewport
-    Improve import of .vrscene files via Sopcreate > vrayScene node
-    Make instance-able slow IPR update
-    The user_attributes parameter of GeomInstancer is empty
-    Motion blur always exported as ON, but no motion blur in the render
-    The Toon Effect from materials is not applied unless enabled in the Render Geometry Settings
-    Separate namespace for viewport render settings
-    VRayScene LOP disable preview is not taken into account
-    VRayScene import mode is wrong when left on the default value
-    Wrong intensity of USD lights
-    Crash with a specific USDZ file when V-Ray is started in the viewport
-    Crash when using the X button in a V-Ray shading graph to visualize a V-Ray Dirt texture
-    Dome light has no parameters in V-Ray tab; Sun light and Area light have settings for Moon and Stars
-    Image File OCIO toggle crash
-    Crash when trying to export vrscenes
-    UV seams with specific geometry when V-Ray Subdivision is applied
-    The prototype transform is ignored for mesh lights
-    Crash when trying to create a subnet from a Layered texture
-    The V-Ray Material Builder appears to dirty the shading graph of adjacent Material type nodes
-    No update for instances when modifying the prototype, scale up the chain
-    Disconnecting a material graph pipe into the Visualize VOP during IPR causes a crash
-    Avoid overwriting paths when V-Ray is used
-    VFB is not shown for husk
-    Incorrect offset with overscan
-    AI Upscaling doesn't work for all resolutions
-    Expose the Dome Light's Affect Alpha parameter in the V-Ray Atmospheric HDA
-    Crash when Intel Open Image Denoiser is used in the viewport
-    Improved IPR toggles updates
-    Tests for MaterialX shaders crash on Linux
-    Implement pattern matching for lights
-    Multi-channel EXRs saved through Hydra delegate do not work with Intel's Denoiser, both in the vdenoise tool and Houdini's idenoise tool
-    File logger support
-    LOP nodes don't get exported to .vrscene
-    Hang if non-hydra or deep output paths do not exist
-    Display licensing messages in the viewport
-    Aerial Perspective does not export the Sun parameters
-    Material library fails to detect animated V-Ray VOP nodes
-    LPE object labels don't work for instances
-    Wrong displacement scale for instances when prototypes have a non-default transform
-    Crash when changing the displacement amount parameter
-    Visibility properties of instanced volumes with new volume shaders are ignored
-    Volume shader IPR update crash
-    Artifacts when rendering two perpendicular planes in the viewport
-    Crash with invalid MultiID texture setup
-    Single subset shader resets on IPR update in some cases
-    NVidia AI Upscale parameter causes flickering of the viewport render
-    mtlxrotate2d not working as expected
-    Crash with Feather Procedural when changing related parameters
-    When using the mtlX displacement node, negative values for the scale cause the geometry to disappear in the viewport
-    Viewport render stats
-    Exponential time to render with 100+ MtlX nodes
-    Crash when multiple subnets are chained in a V-Ray shading graph
-    Rayserver Instancer with Node with ExtMapChannelsis causing a black render
-    Primvars AOVs not rendering without a camera in the Render Settings
-    Subdivision Reserve Geometry Borders in Render Geometry Settings does not affect the final outcome
-    Dome light's Use Tex. from Dome checkbox has no effect
-    Environment setup
Volumes
-    Crash with the new Volume Shader and deep output when Deep Merge Mode is set to 3
-    Crash with a particular setup
-    Only one of the density fields will render when using multiple Volume and VDB Field Assets referencing different SOPs, all under a shared Xform prim
-    Different results between Husk and Solaris viewport rendering when using VDB combined fields
-    Wrong export for volumetrics in vanilla Houdini causes the prototype to be visible
Textures
-    Invalid randomization for big values when using the Random VOP
-    The Size parameter is not translated for the V-Ray Smoke texture
-    Blurred bitmap when using rest attributes with instanced geometry rotated in intervals of 90 degrees
-    COPs are baked differently with the latest builds
VFB
-    Improve the functionality of the masks in the Exposure layer
-    Move Highlight Burn from Exposure layer to Filmic Tonemap - Linear
-    Polygon region's bounding box is cleared in CPU IPR
USD
-    USD 25.X - dirty primitives are not updated
-    USD 25.x Light Linker support
-    Multi-threaded issues with a particular .usd file
-    Missing textures for USDZ file when using usdView
-    Nested rayserver instancers may evaluate the wrong material
-    Wrong build revision in the render log
-    Added primvars:name syntax support for sampling primvars
-    Rendering with usdRecord will occasionally use the wrong camera instead of the one passed through the -cam console argument
MaterialX
-    MtlX Position doesn't work as intended when scene offset is used
-    Fixed an issue with the MtlX Position VOP
-    Override parameters with primvars
-    Assigning mtlx builder not working
-    Anisotropy values closer to 1 cause dark results
-    Fixed ND_heighttonormal scale
V-Ray for Houdiniis a production-proven CPU & GPU rendering software for high-end VFX and animation. It comes with all the tools artists need to render amazing-looking procedural effects. Seamlessly integrated into Houdini, it enables smooth scene exchange and iterations with other DCC applications through full support for USD and a fully-featured V-Ray Hydra Delegate for Solaris.V-Ray 7 for Houdiniintroduces cutting-edge technology and powerful new features, enabling you to build and render more realistic scenes faster than ever. Enjoy easier shader creation, even more seamless shader exchange, next-level creative control, and more.
Getting Started with V-Ray for Houdini
New to V-Ray for Houdini? You're in the perfect place! Our beginner-friendly tutorials will take you through the essentials, equipping you with the knowledge necessary to render stunning stills and animations for your projects. Join us as we explore the V-Ray render engine's interface within SideFX Houdini. Learn how to add the V-Ray Toolbar to the Houdini shelf for quick access to essential tools, settings, and objects. Discover how to start production and interactive rendering, explore the V-Ray Frame Buffer and the Chaos Cosmos asset library UI. Additionally, we delve into creating various light types and materials, navigating nodes, settings, and more.
Chaos Czech a.s.is part of Chaos Group, and specializes in developing easy to use, powerful and affordable software for 3D computer graphics and visual effects. Our technology helps artists and designers create photoreal imagery and animation for design, television, and feature films. Corona Renderer is widely used in arch-viz, automotive and product design, and also features VFX capabilities.
mx8cd.Chaos-V-Ray-7-Update-2-7-20-10-for-Houdini.rar.html
Fileaxa
AlfaFile
https://alfafile.net/file/AFU4Z/mx8cd.Chaos-V-Ray-7-Update-2-7-20-10-for-Houdini.rar
