Free Download Schaefer Informatik Case Relation 1.0.0 (x64) Multilingual Fast Links | 179.1 MbThis app has been created to help you, as a lawyer, work with large PDF files and afterwards easily navigate through them. Case Relation gives you the opportunity to open one PDF file in two columns, which makes it easier to work on the file. Both columns have a separate navigation bar, so you can then highlight and link text from the perspective of the plaintiff and the perspective of the defendant, even if they are located far away from each other in the document.
Highlighted text is displayed under the opened file to make it easier to add descriptions and notes. After highlighting text, you have the opportunity to delete it, edit it, or make a link to the plaintiff or defendant.
After clicking on already-highlighted text, the PDF file will automatically navigate to the point where it is in the document, so you will not waste your time.
Our app gives the opportunity to change the language and customize the highlighted text color by the type of text to make it easier for perception.
In the next step, the Case Relation will show the table where all marked text and notes will appear for reflection. After saving, a new file will be created. To quickly navigate through the document, the first few pages will have a table of contents based on your markings.
Considering that sometimes the file is extensive and it is hard to go through it in one go, in our app, you can upload the new generated PDF file and continue working on it without losing the old markings.
https://apps.microsoft.com/detail/9n0j8w3zkgdg
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorihrs9.Schaefer.Informatik.Case.Relation.1.0.0.x64.Multilingual.rar.htmlFreeDLihrs9.Schaefer.Informatik.Case.Relation.1.0.0.x64.Multilingual.rar.htmlLinks are Interchangeable - No Password - Single Extraction
