06 de Abril de 2026, 01:57 *
Autor Tema: PDFCompressor-CL 1.4.11 (x64)  (Leído 44 veces)
« : 18 de Diciembre de 2025, 12:40 »
Free Download PDFCompressor-CL 1.4.11 (x64) | 26.7 Mb
PDFCompressor-CL is a command line application and serves to optimize and compress PDFs. Optimizes and compresses existing PDF files many times over, depending on the initial situation and settings.
One of the main features of the PDFCompressor component, in addition to the reduction of the resolution, is that PDFs can be created with the latest and best compression methods - JPEG-2000 and JBIG-2 which are not supported by most PDF applications.
It may make sense to unify all PDF files in the company in terms of compression and resolution in order to obtain a uniform standard for all received, processed and archived PDF documents, regardless of where the PDF files came from.
Compress
Compresses existing PDF files many times depending on the initial situation and settings. Removes - unused pages, unused names, invalid bookmarks, invalid links, etc. ZIP compression of all PDF resources.
Images
Optimizing the color depth of images. Change Image Compression - Color, Grayscale, Black & White - LZW, RLE, JPEG, ZIP, JPEG-2000, TIFF Gr.4, JBIG-2. Reduce Images - Convert Images to New Target Resolution Separated for Color, Grayscale, Black & White configurable.
Processing
All settings can be managed via profiles (XML files) - Profile: New, Copy, Change Name, Delete, Export, Import. Parallel processing with configurable number of processes.
Settings
Many setting options for JPEG, JPEG-2000, JBIG-2 compression. Lossless and lossy compression on JPEG-2000 and JBIG-2 configurable.
Operating System:Windows 7, 8/8.1, 10, 11 (64-bit only)
https://www.smallestpdf.com/en/
j536v.PDFCompressorCL.1.4.11.x64.rar.html
