06 de Abril de 2026, 14:44 *
Autor Tema: VectorStyler 1.3.003 Portable  (Leído 43 veces)
Conectado Conectado
« : 20 de Diciembre de 2025, 06:14 »
Free Download VectorStyler 1.3.003 Portable Fast Links | 86.9 MB
VectorStyler brings every advanced vector and illustration tool together - in one complete, independent package, with no subscriptions and no compromises. Packed with powerful, unique tools you won't find anywhere else - VectorStyler redefines what's possible in vector illustration.
Customizable User Experience
Customize all aspects of the user interface and workflow, including shortcuts, menus, toolboxes and toolbars. Create and save your own workspace profiles.
Native Illustrator Import
Open, import or paste artwork from Adobe Illustrator using the native Illustrator file format support, retaining all high-level editable attributes.
Extended Compatibility
Import artwork and export to various common file formats like AI, PDF, SVG, DWG, DXF, PSD, PNG and TIFF. Import and export PSD files while retaining layer hierarchy and keeping editable vectors.
Powerful Snapping Options
Use advanced snapping options for precision, including rotated grids and guidelines, collision and tangent to shape snapping. Turn any object shape into a guideline.
Real Vector Brushes
Paint with and use real vector brushes on any shape or outline. Brushes can be of artistic, pattern, scatter or bristle type. Create new brush styles or presets from any group or layer.
Select Objects by Attribute
Select objects by style or other attributes. Select objects with a similar style or attribute as the selected objects.
Magic Wand Tool
Use the magic wand selection mode and the Magic Wand panel to select objects similar to the pointed object. Select similar shapes by area or length.
Color Palettes
Work with document and global color palettes easily. Open multiple color palettes from external formats. Manage palettes seamlessly.
Advanced Halftones
Create complex vector halftones on layers or images. Work multiple halftones on one object using the Appearance panel
Align Object on Path
Create non-destructive object alignment on path. Align and distribute multiple objects on a path
Vector Drop Shadow
Create vector drop shadow effects on objects or groups. Adjust the drop shadow options using the Drop Shadow panel.
Parametric Shapes
Draw with a large collection of parametric shapes. Adjust shape properties using the Shape panel. Use the Node tool to edit parametric shapes.
System Requirements
- VectorStyler is (also) a native Windows (Intel) application, and requires a PC with Windows 10 installed to run. A minimum of 8GB of system memory is recommended. More memory helps when creating complex designs or illustrations.
- Only Windows 10 or newer versions are supported. An Intel Core i5 or i7 processor with 4 cores and hyper-threading is recommended as VectorStyler makes extensive use of multiple threads. GPU acceleration can be enabled in the Settings / Performance by selecting OpenCL (any GPU supported by Windows), or the NVIDIA mode for Nvidia GPUs.
Homepage-
https://www.vectorstyler.com
z0eak.VectorStyler.1.3.003.Portable.rar.html
