05 de Abril de 2026, 16:45 *
Autor Tema: ViewCompanion Premium 16.24.0.1118  (Leído 49 veces)
« : 20 de Diciembre de 2025, 06:19 »
Free Download ViewCompanion Premium 16.24.0.1118 | 96.3 Mb
ViewCompanion Premium is the most powerful member of the ViewCompanion family. ViewCompanion Premium can view, print and convert Adobe PDF, PDF/A, Autodesk DWF, PLT, CGM, TIFF, CALS, EDMICS and several other file formats. With ViewCompanion Premium you can convert your files to many different output formats, please check the complete list of supported output formats below.
Your PLT, CGM, Gerber and DWF files can be converted into Autodesk DXF format, which can be read by all popular CAD applications, for example Autodesk AutoCAD™. With the built-in PDF to CAD tools you can even convert your PDF files into editable DXF, Gerber, CGM or SVG files.
Both batch convert and batch print is included. The software can be configured to monitor a user defined folder, and all files copied to that folder will be automatically printed using your settings.
You can merge multiple files of different formats to a single multi-page PDF, DWF or TIFF file.
ViewCompanion can split a multipage PDF, TIFF or DWF file into multiple files. You may split a PDF file either based on a maximum number of pages per file or based on the maximum ✅File Size for each output file.
With ViewCompanion you can measure dimension lengths and areas. All measurements can be done using snap to drawing geometry to give the highest accuracy. Calibration of the measurement tools is available to make sure you get correct results even if your drawings are not scaled 1:1. The measurement results may be exported to either a Excel Workbook (XLSX) or to a CSV file which can be opened by any spreadsheet application.
Key Features:
View, markup, convert and print files of many different formats.
Convert to a large number of output formats, please see the complete list of formats below.
Batch printing and conversion is included.
Color, Black & White or Grayscale printing and conversion.
Scaled print or fit to paper.
Poster mode for printing big format drawings on multiple sheets, e.g. print an A0 drawing in full size using multiple A4 sheets.
N-up printing mode, also known as multiple pages per paper sheet printing.
Hot folder printing. Monitor a folder and print all files that are copied to this folder.
Add footer and header containing date, scale, time, filename or custom text to the printed file.
Annotate your files by adding text, symbols, stamps, barcodes, images, measurements and more.
Include annotation during printing and conversion.
Precise measurement with snap to drawing geometry.
Send the viewed file by e-Mail, either as a PDF, as a JPEG or in the original format.
Conform, or convert, any PDF file into PDF/A standard for archiving. Batch and single file supported.
Compare two files and visualize the differences.
Compare multi-page PDF files, page by page.
Merge different PDF files into a single multipage PDF file.
Split a multipage PDF file into individual files.
Digitally sign PDF files.
Optimize PDF files.
Split a multipage TIFF file into individual files.
Scan and create a new file or add as page to active file.
Includes advanced raster processing tools to deskew, cleanup, remove foxing and more.
Optional OCR, Optical Character Recognition, support using the free Tesseract engine.
Overlay up to 10 files and print as one drawing.
Apply watermark using text, or an image, to the printed file.
Use pen table for full control of colors, styles and widths.
Copy a selected region, or whole drawing, to clipboard, and paste into other applications.
Text search and extract.
Store commonly used files in projects.
Shell Extension for easy access to functions inside the Explorer Window and a full preview of the selected file.
Extensive set of command line parameters for conversion and printing.
Delete pages from multipage files (e.g. TIFF and PDF).
Use the PDF to CAD tool to convert your PDF files into editable DXF, DWF, PLT, SVG and CGM files.
Supported Operating Systems
Windows 7, 32 and 64 bit
Windows 8, 32 and 64 bit
Windows 8.1, 32 and 64 bit
Windows 10, 32 and 64 bit
Windows 11
Windows Server 2008 R2
Windows Server 2012
Windows Server 2016
Windows Server 2019
Windows Server 2022
Windows Server 2025
Supports Terminal Server and Citrix
Home Page-http://www.softwarecompanions.com/
Visit All My News
1ke2r.ViewCompanion.Premium.16.24.0.1118.rar.html
