06 de Abril de 2026, 05:58 *
Autor Tema: ClipboardFusion Pro 6.3 Multilingual  (Leído 39 veces)
« : 21 de Diciembre de 2025, 02:15 »
Free Download ClipboardFusion Pro 6.3 Multilingual Fast Links | 9.2 Mb
ClipboardFusion makes it easy to remove clipboard text formatting, replace clipboard text or run powerful macros on your clipboard contents! You can even sync your clipboard with other computers and mobile devices.
Remove Clipboard Formatting
ClipboardFusion scrubs text copied to the clipboard so that it can be pasted into different applications without formatting. It can be done automatically or with a customizable HotKey.
Replace Clipboard Text
ClipboardFusion can replace clipboard text with pre-defined strings. Maybe you want to replace all '&' symbols with their HTML equivalent, & - it's up to you!
HotKeys
Quickly access ClipboardFusion by setting up customizable key combinations you can press at anytime. ClipboardFusion is always at your fingertips!
Use Powerful Macros
Create your own macros using C# in the integrated editor to perform completely customized transformations on your text. The power of the macros is only limited by your imagination. Also, be sure to check out the pre-made Macros, created by other members of the ClipboardFusion community.
Triggers
Customize the way you use your Clipboard by setting up different actions to do almost anything you can think of - in the blink of an eye!
Sync Your Clipboard
Create a Binary Fortress Account and sync your clipboard text with other computers or devices, or just store it so you can use it again later. Sync with Android, Apple iOS, BlackBerry, Windows Phone, Windows 8 (Metro) and more. Sharing your clipboard with all of your devices has never been easier!
Clipboard Manager
The ClipboardManager is the main focal point of ClipboardFusion. You can view your Clipboard History, Pinned Items, Online Items, and your custom Macros. Edit, pin, sync, search, reorder, and use your items all from one window!
Security is Everything
Everything you send or receive using the Clipboard Syncing feature is encrypted using 256bit encryption.
ClipboardFusion works with these versions of Windows:
Windows 10, 8.1, 8, and 7 (32-bit and 64-bit)
Windows Server 2016, 2012 R2, 2012, and 2008 R2 (32-bit and 64-bit)
Home Page-http://www.binaryfortress.com/
jggnu.ClipboardFusion.Pro.6.3.Multilingual.rar.html
