04 de Abril de 2026, 23:20 *
Autor Tema: CLO Standalone OnlineAuth 2025.2.236 Multilingual (x64)  (Leído 46 veces)
« : 22 de Diciembre de 2025, 22:11 »
Free Download CLO Standalone OnlineAuth 2025.2.236 (x64) Multilingual Fast Links | 2.1 Gb
CLO is the most advanced, intuitive, and cohesive software of its kind. Dive right into design. Get inspired by prepared pattern blocks and sketch directly on your avatar to generate pattern pieces automatically.
Real materials, simulated
Our true-to-life 3D garments make it easy to fine-tune the fit of your designs - even for drape-sensitive fabrics, like lightweight wovens and jerseys.
Explore endlessly
With 100% accurate digital samples, you can explore every idea and inspiration freely in the most sustainable way - at no cost.
Showcase and merchandise
Evolve your E-commerce by using our natural simulation environment to display and merchandise your 3D garment collections as soon as you create them.
2025.2 New Features
Seamless Blocking
Design seamless styles by applying different fabrics within a single pattern without any sewing lines.
Denim Wet Wash Effect
Easily apply various denim washes such as stone, enzyme, and bleach.
Upgraded 3D Pen
Draw garment silhouettes around the avatar directly from the 3D space, and instantly convert them into 2D patterns.
CLO zFab Kit x CLOFAB
Digitize fabrics quickly and precisely with enhanced CLOFAB tools - built to integrate seamlessly with the new CLO zFab Kit, our hardware-based fabric digitization system.
Zipper Style
Manage identical zipper styles as a single item for faster and more efficient workflow.
CLO AI Studio
Experience all AI-powered features in one place with CLO AI Studio, and access new AI tools faster than ever.
Seamless CLO-SET & CONNECT Experience
Now seamlessly access and use CLO-SET and CONNECT features within CLO, all in a consistent and unified workflow.
AI Embroidery Graphics
Generate embroidery graphics from simple keyword prompts, or instantly transform uploaded images into embroidery-style visuals.
Pattern Drafter Improvement
Now create parametric patterns from both schematic images and garment photos.
Set Grade Point
Apply grading selectively at individual points for precise control.
Extend/Trim to Unfolded Line
Extend internal lines to match the unfolded line.
Internal Line
Quickly group internal lines using shortcuts, with grouping preserved during pattern edits.
Notch Improvement
Customize default notch length and shape, and place them more accurately at seam allowance corners.
3D Topstitch Schematic Render
Customize topstitch visuals to match your preferred schematic style.
Blend Print with Fabric
Blend prints with fabric textures to achieve a more realistic and cohesive visual effect.
Soft Body Simulation Improvement
Apply soft body simulation not only to CLO avatars but also to non-rigged custom avatars for more realistic deformation and movement.
Open/Add Specific Colorways
Choose specific colorways to import when opening or adding garment files.
Colorway Usability Improvement
Easily view and edit button and topstitch components in the Colorway Editor, and save snapshots in high resolution.
glTF
Export glTF with avatar animations.
Keyframe Animation Improvement
Apply keyframes to render lights and quickly adjust the animation playback range based on specific layers
Avatar Wireframe View
View the mesh structure of the avatar while maintaining your preferred rendering style. Translucent Surface view is also supported.
Flattening Improvement
Flatten multiple intersecting areas as a single pattern.
Trim Status Visualization
View the simulation status of trims at a glance using color indicators.
Flexible ZPAC Save
Save only selected patterns and trims, along with 3D/2D display settings, to maintain a consistent working environment.
Show/Hide Scene and Props
Instantly show or hide Scene & Prop objects.
3D File Import & Export Preset
Save import and export settings as presets for 3D files to streamline your workflow.
2D Snapshot
Freely customize the style and color of 2D pattern segments.
Decimal Place Settings
Customize the number of decimal places for the system unit in use, from 1 to 5 digits.
https://www.clo3d.com/en/
sa47d.CLO.Standalone.OnlineAuth.2025.2.236.x64.Multilingual.part1.rar.html
sa47d.CLO.Standalone.OnlineAuth.2025.2.236.x64.Multilingual.part2.rar.html
