06 de Abril de 2026, 11:38 *
Autor Tema: nTopology 5.37.3 Win x64 English  (Leído 58 veces)
« : 23 de Diciembre de 2025, 18:32 »
Free Download nTopology 5.37.3 | 1.5 Gb
nTopologyis pleased to announce the availability ofnTopology 5.37.3. This release introduces new Field Viewer visualization options for inspecting discontinuities and zero values, as well as spatially varying boundary conditions for Flow Analysis.
Owner:nTopology
Product Name:nTopology
Version:5.37.3
Supported Architectures:x64
Website Home Page :www.ntop.com
Languages Supported:english
System Requirements:Windows *
nTop 5.37 - What's New
Field Viewer Improvements
-Zero and Discontinuity Visualization:We added new visualization toggles to the Field Viewer (shortcut F) in the right side panel to help you inspect fields:
.Show Defects:This option visualizes areas where the field value changes abruptly (discontinuities).
.Highlight Zero:This option renders a yellow contour line indicating where the field values equal zero. Use this to verify the exact boundary of an implicit body and prevent downstream issues during shelling or offsetting operations.
-Infinite and NaN Value Rendering:Infinite (Inf) and NaN values now appear as a grey and white checkerboard pattern, making them easily distinguishable from the rest of the field. The color map also now ignores these values, making the rest of the field more legible.
Block Updates
-    We have enabled spatially varying boundary values as inputs for Flow Analysis and Aircraft Flow Analysis blocks that use nTop Fluids. Boundary conditions can now be defined using spatially varying data fields. This enables complex, non-uniform scalar or vector fields to be mapped directly onto simulation boundaries, eliminating the need to rely solely on constant values.
-    We have updated the Parameter Optimization block to reduce the time taken for the normalization step and to improve the results. All previous results are cached and unchanged. However, rerunning the block may produce different results.
Bug Fixes
We resolved an issue where importing .vtu/.vtk files could result in empty or incomplete data being returned in some cases. This fix restores full functionality to the following blocks:
-        Import Buckling Result
-        Import Modal Result
-        Import CFD Analysis Result
-        Import Static Thermal Result
-        Import Static Structural Result
-        Import Time Dependent Thermal Result
-        Import Time Dependent Structural Result
nTopologyintroduced the concept of implicit modeling for mechanical design, which is an innovative, modern, and scalable way define parts and products. It has many benefits to end-users and companies, such as the elimination of model failures, speed of changes or iterations, and scalability to name a few. But implicit modeling enables so much more. In this informational session, we'll explore a topic that is redefining product development - field-driven design. In short, field-driven design is a way for design, analysis, and manufacturing teams to overlay information into one engineering model. This approach enables orders of magnitude increase in design iteration speed and greatly improves collaboration between teams.
How Field-Driven Design Allows Engineers to Design for Additive Manufacturing
Watch this information session where we'll define field-driven design, show examples of how it enables better knowledge sharing, and show how it promotes the development of more sophisticated, highly engineered products. You'll also better understand how nTopology is addressing today's engineering problems through its nTop Platform product.
nTopologywas founded in 2015 to enable engineers and designers to create any geometry - no matter how complex - and meet the requirements of high-performance products.
yvdd8.nTopology-5-37-3.rar.html
