06 de Abril de 2026, 07:50 *
Autor Tema: Siemens Simatic TIA Portal V21 (2025.11) Win x64  (Leído 52 veces)
« : 23 de Diciembre de 2025, 18:32 »
Free Download Siemens Simatic TIA Portal V21 (2025.11) | 26.4 Gb
Languages Supported: English, Français, Italiano, Русский, Español
Siemenshas releasedTotally Integrated Automation (TIA) Portal V21. The release is aimed at both machine builders developing innovative machines based on an efficient engineering workflow and discrete manufacturing companies aiming to ensure more powerful and reliable production.
Owner:Siemens Digital Industries (DI)
Product Name:Totally Integrated Automation (TIA) Portal
Version:V21 (2025_11) *
Supported Architectures:x64
Website Home Page :
https://support.industry.siemens.com/
System Requirements:Windows **
The TIA Portal V21 accelerating the transition to software-defined automation. Git-based CI workflows shorten development cycles, while high-availability SCADA architectures ensure that our customers can keep their plants running more efficiently and adapt them flexibly to new market requirements.
Greater efficiency in engineering through improved and integrated workflows
TIA Portal V21 focuses on higher engineering efficiency and end-to-end standardization. A new export format enables seamless integration of established version control systems such as Git for the first time. This applies to LAD, FBD, SCL, data blocks, PLC data types and mixed-language blocks and many others. This enables STEP 7 users to benefit from optimized continuous-integration workflows, simplified versioning and maximum compatibility. All of this forms the basis for shorter project runtimes and reliable traceability of all changes.
Higher availability thanks to SCADA architecture
Supervisory Control and Data Acquisition (SCADA) applications based on WinCC Unified can now be operated in redundant server architectures that ensure continuous operation and significantly higher availability. In addition, the WinCC Unified Data Hub, acting as a central archive, provides access to and long-term storage of production data, messages and audit trails from multiple WinCC Unified PC runtimes, helping to create continuous, plant-wide data transparency over long periods of time.
What's new in Totally Integrated Automation (TIA) Portal V21
The below is a snapshot of the highlights will be most valuable for Siemens customers.
3rd Party Version Control Software Support Improvements
Support for 3rd party 'Modern' software version control software has been strengthened. For those of you who use GIT Hub or similar for your version control, this is a great upgrade. The key enabling feature is called "SIMATIC Source Documents', and the exported and subsequently imported files now consist of human readable code, not simply slugs of binary that was once the case. Get in touch with our team for details on this, if you use or are considering using such external version control system for your Siemens Industrial Automation code.
Avoid Data Block Re-Initialisation for Structural Changes
NOTE: This feature requires both TIA-V21, and Siemens PLCs running Firmware Version 4.1.
As many of you will know, changing the structure of data blocks (e.g. add or remove variables) in the past has invariably meant that the system re-initialises all values back to default. Obviously this means extra care, attention, and typically stopping your machine or process is required.
In TIAV21, with PLCs running Firmware version 4.1 one can avoid this re-initialising in many cases. Particularly when adding or deleting elementary data types. As many of our readers here will attest to, this will be super helpful.
Multiuser Enhancements
Totally Integrated Automation Portal has Multiuser capabilities as many of you know, and some of you use. The innovation in V21 is removing the need to "Synchronise the PLC after a Multiuser Check-in and refresh from the project server". A lovely time saver.
Motion Control - Multicore Support
For motion control technology objects, one can now spread the load over more cores of Siemens' newer Multicore PLCs. With the option "Improve System Performance" checked within a technology object OB, the controller will share the processing load over two of the four cores rather than it all staying on the one core as previously. This can reduce technology object processing time by up to 30%.
Motion Control - Enhanced Technology Object Tracing
Tracing has been enhanced in TIAV21 for motion control technology objects, bringing it more in line with the exceedingly powerful trace functions available with Simotion Scout. The additional trace functionality will give users more meaningful insight into Technology Object (TO) behaviour for system understanding and debugging.
SINAMICS Start Drive V21 Highlights
New hardware support, as well as engineering efficiency improvements are the core here:
1.      Support for the new control unit for the S220 range (Eventual successor to S120), this S220 control unit is know as the CU320-3. Look out for our coming blog post with additional information on the CU320-3, which is being released with several other S220 innovations at the SPS trade fair in Nuremberg, November 25th until 27th 2025.
2.      Extended drive compare function, for up to 5 drive objects at one.
3.      Mass firmware upgrade for multiple drives.
4.      Configure traces directly on next generation Siemens Sinamics drives.
5.      Direct support for R/H Systems. This permits configuring drives in S2 redundancy connected to S7-1500R (redundant) or S71500H (High availability) using Sinamics Start Drive.
Simatic S7-1200 G2 Enhancements
The Simatic S7-1200 G2 PLC is based on the same internal hardware architecture as the S7-1500. So with TIAV21, a new S7-1200 G2 firmware release (To FW V4.1) brings the firmware versions in line between the S7-1200 G2 and S7-1500 PLC lines.
With the new release of firmware, the S7-1200 G2 gains the following features we think our customers in New Zealand will find most useful:
NOTE: These will be very familiar to our existing S7-1500 customers:
1.      OPC UA Server.
2.      System web pages served from onboard.
3.      Additional motion control functions.
4.      S7-PLCSIM Advanced Support.
5.      Modbus TCP redundancy instructions.
6.      PROFINET security class 1.
Regarding additional hardware releases for the S7-1200 G2, as part of the progressive replacement of the S7-1200 original, the following are being released in parallel with TIA V21.
1.      SM 1223 DI 16x 24VDC/DQ 16x relay
2.      SM 1223 DI 16x 24VDC/DQ 16x 24VDC Sink
3.      SM 1223 DI 16x 24VDC/DQ 16x 24VDC
4.      Battery Board (maintains system clock and retain values on power failure)
5.      Communication Processor CP 1243-1 G2 (Additional Ethernet Port)
S7-1200G2 safety modules are not being released at this time, and are due for progressive release during calendar year 2026. Hence as many of our customers are currently doing, one can use ET200SP safety I/O as remote I/O to the S7-1200G2 safety PLCs, to bring in and send hard wired safety signals. (As well as obviously network Profisafe to the extensive range of Sinamics drives and any other hardware that supports Profisafe communication from both Siemens and the many 3rd parties who sell such devices).
Cyber Security
TIA V21 and the associated new firmware for S7-1500 and S7-1200 G2 PLCs further enhance the security of Siemens PLC systems within the broader Cyber Security framework. Siemens is working towards ensuring that all of their 'digital industries' networked devices, and their underlying ecosystem will adhere to the "European Union Cyber Resilience Act" that is coming into effect in approximately two years time. So we will see continued progressive security upgrades over time.
S7-1500 CPU Enhances System Web Pages.
The system web pages have been enhanced with firmware V4.1. So when you get your next new Siemens S7-1500 CPU from us, connect into it and check out the new web pages. Particularly if you don't currently use the default web page functionality. Enhancements and additions have been made around:
1.      Extended basic information
2.      Extended virtual operator panel.
3.      Enhanced hardware status window
4.      Service data download
5.      Motion control diagnostics
6.      Failsafe system administration.
There may be something in the above that smooths and/or speeds your diagnostics/maintenance/fault finding procedures going forward. (Or maybe de-skills them, so more people can help out when required).
S7-1500 Redundant PLC System Enhancements
Many enhancements have been made, but the one that we feel our customers will get most benefit from is:
1.      Allowing Hardware Configuration changes in Run. E.g.:
a.      Add new PROFINET IO-Device in Run
b.     Change IO-Module settings in Run (E.g. enable wire break detection).
S7-1500 Software Controller / IPC Enhancements
For those of you who your IPCs (industrial PCs), you know Siemens has a huge range of power and form factors available. A couple of additions worth mentioning are:
1.      Addition of Software Safety PLC to more IPC models.
2.      Nvidia GPU-Card Support extended:
a.      Supports up to two GPUs, enabling more complex AI solutions directly on machine, in the field.
3.      Additional security measures, such as "Secure boot".
TIA Portal Safety Validation Assistant
Further enhancements and supported hardware additions have been made. What do I use 'TIA Portal Safety Validation Assistant' for? It provides:
1.      Guided validation of the machine safety functions.
2.      Easily validate the entire chain of safety functions using the in-built guided test wizards.
3.      I.e. It validates and exports a single test report from Sensor to Actuator of each safety function. It supports Simatic, Sinamics and Sirius products. The tool is qualified against IEC31508-4 from TIA V21.
TIA Portalis a software and tools package developed by Siemens, which aims to integrate multiple development tools for automation devices from the unification and remodelling of preexisting software such as Simatic Step 7, Simatic WinCC, and Sinamics Starter. The environments are responsible for programming, developing, and configuring Siemens PLCs, HMIs, and frequency inverters. The user's programming logic in TIA Portal follows a structure of blocks, a facilitating agent for the development, maintenance, and diagnostics of machines and industrial processes when developed in a structured and organized way.
What is Siemens Tia Portal? - Siemens PLC Software Packages
In this video, you will learn the Siemens Tia Portal (Totally Integrated Automation Portal) and other Siemens PLC software packages.
Siemens Digital Industries (DI)is an innovation leader in automation and digitalization. Closely collaborating with partners and customers, DI drives the digital transformation in the process and discrete industries. With its Digital Enterprise portfolio, DI provides companies of all sizes with an end-to-end set of products, solutions and services to integrate and digitalize the entire value chain. Optimized for the specific needs of each industry, DI's unique portfolio supports customers to achieve greater productivity and flexibility. DI is constantly adding innovations to its portfolio to integrate cutting-edge future technologies. Siemens Digital Industries has its global headquarters in Nuremberg, Germany, and has around 75,000 employees internationally.
SIMATIC_WinCC_Unified_Station_Configurator_V21.exe
TIA_Portal_STEP7_Safety_WinCC_V21_(Français, Italiano, Русский, Español).exe
SIMATIC_S7-PLCSIM_Advanced_V8.iso
SIMATIC_SCADA-RT_V21.iso
SIMATIC_WinCC_Reporting_Add_In_ONE_V25.iso
SIMATIC_WinCC_Unified_RT_V21.iso
SINAMICS_DCC_V21.iso
SiVarc_V21.iso
STARTDRIVE_BASIC_ADVANCED_V21.iso
TIA_Portal_STEP7_Safety_WinCC_V21.iso
TIA_Portal_STEP7_Safety_WinCC_V21_DVD2_V21.iso
SIMATIC_STEP7_CFC_V21.zip
WinCC_Unified_RT_Debugger_Extension_V25.zip
UMC_V2_15_2_1.zip
s26ou.Siemens-Simatic-TIA-Portal-V21-2025-11.part01.rar.html
s26ou.Siemens-Simatic-TIA-Portal-V21-2025-11.part02.rar.html
s26ou.Siemens-Simatic-TIA-Portal-V21-2025-11.part03.rar.html
s26ou.Siemens-Simatic-TIA-Portal-V21-2025-11.part04.rar.html
s26ou.Siemens-Simatic-TIA-Portal-V21-2025-11.part05.rar.html
s26ou.Siemens-Simatic-TIA-Portal-V21-2025-11.part06.rar.html
s26ou.Siemens-Simatic-TIA-Portal-V21-2025-11.part07.rar.html
s26ou.Siemens-Simatic-TIA-Portal-V21-2025-11.part08.rar.html
s26ou.Siemens-Simatic-TIA-Portal-V21-2025-11.part09.rar.html
