Free Download IDEA StatiCa 25.1.2 (1278) | 733.6 mbLanguages Supported: English, Čeština, Nederlands, Français, Deutsch, Magyar, Italiano,
Polski, Română, Slovenčina, Español, Русский, Português (BR)IDEA RShas released
IDEA StatiCa 25.1.2 (1278)is an engineering software dedicated to structural design and code-check of joints, cross-sections, beams, and other details in structures.
Owner:IDEA RS
Product Name:IDEA StatiCa
Version:25.1.2 (1278)
Supported Architectures:x64
Website Home Page :www.idea-rs.comLanguages Supported:multilanguage
System Requirements:Windows *
Version 25.1 brings major improvements across steel, concrete, and connection design, alongside smarter integrations and performance boosts that redefine everyday workflows.Release notes IDEA StatiCa 25.1Concrete DesignDetail3D analysis- Anchor types (headed studs, washer plates, smooth rebars)
- Update of Cast-in plates
- Anchoring plates options
- Anchors tied to the base plate and referenced to the center
- Stub of steel member for load transfer
- Australian code for anchoring
2D analysis- Unbonded tendons
- Smooth rebars
- Australian code for prestressing
Common improvements- Advanced result representation
- UK concrete grades
Beam- LTB results included in Beam and torsional stiffness definition
Steel DesignEnhancements in the anchoring design- Anchor type selection for better understandability
- Cast-in plates (Eurocode)
- Anchoring on different planes
- Two base-plates (operations) in one block
- General anchor database
Improvements in the design templates- Multiple templates applicable to one model
- Improvements of the predefined set
- Bulk import of templates to Connection Library
Customization of your projects- Saving the report defaults for every Connection project
- Saving the general cross-section into MPRL
Regional improvements- WT sections added to the library (AISC)
- Implementation of ACI 318-25 (AISC)
- Anchorage checks in the Indian Standard (IS)
- New languages - Bulgarian, Croatian, Ukrainian, Traditional Chinese
Accuracy of the results, safety of the project- Update of the FEM mesh for CHS members
- Stepped analysis in Member
- Buckling calculation of models with pins
- Large deformation warning
BIM and CheckbotCheckbot workflows- Alignment of members by cross-section
- Calculate buckling analysis for all connections
- Bulk calculation progress bar and cancel
- Bulk report for all connections in the Checkbot project
BIM links- ETABS and SAP2000 BIM link to Detail
- Connection API functions update
- Supported BIM links in version 25.1
Cloud tools and general improvements- Bookmarks for Connection Library
- Connection project shared via email
- Extended tooltips in apps help with clarity
IDEA StatiCais an industry-leading structural design software solution for architect and structure designers that can help them to check the integrity and features of steel connections, joint integrity, anchoring, footing, and connection in their modern steel or concrete topologies. For easy integration in your regular workflow, developers of IDEA StatiCa have worked tirelessly to ensure complete compatibility with all the most popular workshop drawing apps and manufacturing process designs created in apps such as Robot, Revit, MIDAS Civil + Gen, STAAD.Pro, SAP 2000, Scia Engineer, RFEM, RSTAB, AxisVM, ConSteel, and others. IDEA Statica represents an important analysis tool that can help you quickly test the integrity of your design and provide a complete report with drawings and clear pass/fail scores.
What's new in IDEA Statica 25.1IDEA RSdevelop software for structural engineers, fabricators, consultants and all others who perform or use structural analysis. Our development team researches, tests and applies new methods of analyzing behavior of structures and their members. Based on this, we create IDEA StatiCa - software that enables engineers to work faster, evaluate requirements of the national code thoroughly and use optimal amount of material. For us, creating software is a way to contribute to making every new construction around the world safer and cheaper.
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorfkmib.IDEA.StatiCa.25.1.2.1278.rar.htmlDDownloadfkmib.IDEA.StatiCa.25.1.2.1278.rarFreeDLfkmib.IDEA.StatiCa.25.1.2.1278.rar.htmlLinks are Interchangeable - No Password - Single Extraction
