06 de Abril de 2026, 02:09 *
Autor Tema: Carly - OBD2 car scanner v49.71  (Leído 28 veces)
« : 23 de Diciembre de 2025, 23:58 »
Free Download Carly - OBD2 car scanner v49.71 | Android | 91.3 MB
Carly is the most versatile OBD2 solution, offering diagnostics, engine live data, and guides for car repair and maintenance.
Get the Carly app and the Carly Universal Scanner to access data through the OBD2 port of your car.
Unleash your inner car hero with Carly!
It works for Audi, BMW, Ford, Lexus, Mercedes, Mini, Opel, Porsche, Renault, Seat, Skoda, Toyota, VW, and almost all other car brands with an OBD2 port.As every car is unique, which specific Carly features are available will vary with every model, build year, hardware, and software.
BASIC FEATURES INCLUDED IN THE (FREE) BASIC PACKAGE
- Diagnostics (OBD), Live Data (OBD), and Emission Check (OBD) enable you to have control over the most important systems - engine and transmission.
UNDERSTAND YOUR CAR'S HEALTH
- With Carly Diagnostics, you can read and clear fault codes from all built-in electronic control units (ECUs), including engine, transmission, ABS, airbag, and multimedia, keep track of your car's health, gauge the severity of problems, and more.
POWERCHARGE YOUR REPAIR SKILLS
- Get expert repair guides for your specific issues to help you understand and fix the issues by yourself.
MONITOR ENGINE LIVE DATA
- Live parameters or live data can help you take the guesswork out of understanding what your car needs and narrow down the fault causes.
PERFORM CAR MAINTENANCE INDEPENDENT OF THE WORKSHOP
- The Carly Maintenance feature helps you step-by-step to service your car yourself, reset your service and keep track of your service intervals directly from your phone.
VIEW THE CONDITION OF YOUR BATTERY
- The Carly Battery Check function helps you monitor the status of your car's starter battery, which will help to increase your batterie lifetime.
CODE AND UNLOCK HIDDEN FEATURES
- Access hidden features set by the manufacturer and customize your car to fit your needs. This feature is only available on certain car brands/models, and the coding options vary between each control unit.
DETECT MILEAGE MANIPULATION
- Mileage manipulation is on the rise. Don't get tricked when buying a used car - use Carly to perform a used car inspection before buying.
HOW IT WORKS
- Step 1: Check which features are available for your car model
- Step 2: Order your Carly Universal Scanner
- Step 3: Plug the scanner into the OBD2 port and log in on this app
THE CARLY UNIVERSAL SCANNER - THE MOST ADVANCED OBD DEVICE
The OBD2 device was designed to support almost all car brands with an OBD2 port and to enable advanced Carly features. The scanner comes with
- A lifetime warranty
- Premium customer support
Requirements: Android 8.0+
https://play.google.com/store/apps/details?id=com.iViNi.bmwhatLite&hl=en
kouuc.Carly..OBD2.car.scanner.v49.71.apk.html
