Free Download PostgreSQL Maestro 25.9.0.1 Multilingual Fast Links | 47 MbPostgreSQL Maestro is the premier Windows GUI admin tool for development and management of PostgreSQL databases. It allows you to make all the database operations easy and fast. Using PostgreSQL Maestro you can operate database objects, build queries visually, represent databases as ER diagrams, execute queries and SQL scripts, view and edit data including BLOBs, represent data as diagrams, compose OLAP cubes, export and import data to/from most popular file formats, manage access privileges, and use a lot of other tools designed for the easiest and most efficient work with PostgreSQL server.
Easy database management
PostgreSQL Maestro allows you to create and drop databases quickly. Database profiles give you the opportunity to connect to databases in one touch and work with the selected databases only.
Powerful database object management
PostgreSQL Maestro provides you with an ability to manage database objects. For example, you can perform operations with a group of objects as well as with a single object in Object Manager, sort, group and filter the database objects within Object Browser, copy an object from one database to another by a drag-and-drop operation inside the explorer tree, use Windows clipboard to copy a set of objects and so on.
Working with tables and table subobjects
PostgreSQL Maestro wizards and editors allow you to create, edit and drop tables as well as their fields, indexes, triggers and foreign keys in a couple of simple operations.
Building and executing queries
PostgreSQL Maestro provides two powerful tools which allow you either to edit query text directly with syntax highlighting and code completion or to build a query diagram visually selecting tables and fields, setting links between tables and so on.
Support of the latest PostgreSQL features
Use PostgreSQL Maestro to work with PostgreSQL from 7.3 to 12.0! Among other features and objects implemented in the latest versions of the server, our software supports role system, tablespaces, parameter scopes, connection limits, ascending and descending indexes, and much more.
Powerful data management tools
With PostgreSQL Maestro you can view and edit table data (including BLOB fields), export and import data to/from MS Excel, MS Access, DBF, XML, TXT, CSV and other formats, get SQL data dump and more.
Work with database metadata
PostgreSQL Maestro provides you with a number of tools for working with database metadata and SQL scripts, including code folding.
Security management
PostgreSQL Maestro provides you with an efficient way to manage access privileges. You can either grant/revoke permissions for a concrete database object such as table or function, or operate with grantees' privileges in their editors.
Easy PostgreSQL run-time configuration
PostgreSQL Maestro helps you to assign a set of option settings either to a user or to a database in a few mouse clicks. Overriding of the default server settings becomes easy too.
Full customization according to your preferences and needs
You can customize the software behavior, select a user interface scheme and set a lot of other preferences.
System Requirements:Pentium PC or higher;
Windows NT4/2000/XP/Vista/Windows 7/Windows 8/Windows 10/Windows 11;
1 GB RAM (2 GB or more is recommended);
50 MB of free hard disk space;
SVGA-compatible video adapter.
Home Page -https://www.sqlmaestro.com/
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorxagjj.PostgreSQL.Maestro.25.9.0.1.Multilingual.rar.htmlDDownloadxagjj.PostgreSQL.Maestro.25.9.0.1.Multilingual.rarFreeDLxagjj.PostgreSQL.Maestro.25.9.0.1.Multilingual.rar.htmlLinks are Interchangeable - No Password - Single Extraction
