06 de Abril de 2026, 12:39 *
Autor Tema: G-Stomper Studio v6.1.0.1  (Leído 43 veces)
« : 26 de Diciembre de 2025, 15:36 »
Free Download G-Stomper Studio v6.1.0.1 | Android | 75.5 MB
Paid version
G-Stomper Studio is a Music Production Tool, highly optimized for doing Electronic Live Performances in Studio Quality.
It's a feature packed, Step Sequencer based Drum Machine/Groovebox, a Sampler, a Virtual Analog Performance Synther (VA-Beast), a polyphonic + a monophonic Step Sequencer for melodies, a Track Grid Sequencer for Beats, a Piano Keyboard, 24 Drum Pads, an Effect Rack, a Master Section, a Line Mixer and a Live Pattern/Song Arranger. Wherever you are, take your mobile device and start straight away creating your own music.
The integrated VA-Beast is a polyphonic virtual analog Synther to produce complex synthetic sounds of any variety, designed for experienced sound designers as well as for beginners. So it's up to you if you just explore the Factory sounds or if you start right away with designing your own sounds in impressive studio quality. Its sound capabilities paired with the intuitive and clearly laid out interface simply makes G-Stomper VA-Beast to the ultimate Mobile Synther. You will be able to create the sounds you want, and you'll do it faster than on any other mobile synther.
Instruments and Pattern Sequencer
- Drum Machine: Sample based Drum Machine, max 24 Tracks
- Sampler Track Grid: Grid based Multi Track Step Sequencer, max 24 Tracks
- Sampler Note Grid: Monophonic Melodic Step Sequencer, max 24 Tracks
- Sampler Drum Pads: 24 Drum Pads for live playing
- VA-Beast Synther: Polyphonic Virtual Analog Performance Synther (Advanced FM support, Waveform and Multi-Sample based Synthesis)
- VA-Beast Poly Grid: Polyphonic Step Sequencer, max 12 Tracks
- Piano Keyboard: On various Screens (8 Octaves switchable)
- Timing & Measure: Tempo, Swing Quantization, Time Signature, Measure
Mixer
- Line Mixer: Mixer with up to 36 Channels (Parametric 3-band Equalizer + Insert Effects per Channel)
- Effect Rack: 3 chainable Effect Units
- Master Section: 2 Sum Effect Units
Arranger
- Pattern Set: Live Pattern/Song Arranger with 64 concurrent Patterns
Audio Editor
- Audio Editor: Graphical Sample Editor/Recorder
Feature Highlights
- Ableton Link: Play in sync with any Link-enabled app and/or Ableton Live
- Full round-trip MIDI integration (IN/OUT), Android 5+: USB (host), Android 6+: USB (host+peripheral) + Bluetooth (host)
- High Quality Audio Engine (32bit float DSP algorithms)
- 47 Effect Types including Dynamic Processors, Resonant Filters, Distortions, Delays, Reverbs, Vocoders, and more + Side Chain Support, Tempo sync, LFOs, Envelope Followers
- Per Track/Voice Multi-Filters
- Real-Time Sample Modulation
- User Sample Support: Uncompressed WAV or AIFF up to 64bit
- Tablet optimized, Portrait Mode for 5 inch and bigger screens
- Full Motion Sequencing/Automation Support
- Import MIDI files/songs as Pattern Set including Song arrangement
Requirements: Android 8.0+
https://play.google.com/store/apps/details?id=com.planeth.gstomper&hl=en
9umxh.GStomper.Studio.v6.1.0.1.apk.html
