06 de Abril de 2026, 07:31 *
Autor Tema: Halfpricesoft ez1095 v12.0.3  (Leído 54 veces)
« : 26 de Diciembre de 2025, 15:38 »
Free Download Halfpricesoft ez1095 v12.0.3 | 5 Mb
Being in charge of a small company usually involves you having to perform numerous managerial tasks, such as filling or handing various forms to your employees.
While some of the tasks can be completed manually by relying on traditional methods, such as pen and paper, turning to specialized software, such as ez1095, might help you achieve quicker results.
Please note that this application requires you to have .NET Framework installed on your computer to run as intended.
Lightweight application that features a simplistic user interface
This program can help you boost productivity by saving you time spent generating forms for your employees. It packs a minimalistic user interface that integrates straightforward functions, therefore allowing a broad range of users to benefit from its capabilities without effort.
Unfortunately, it does not come with any form of local help documentation. Therefore, if you encounter any difficulty while operating this utility, relying on a help manual is not an available option.
Helps you generate, fill and print 1095B and 1095C forms
ez1095 allows you to create Affordable Care Act (ACA) 1095 forms, fill the required information and print them, so you can hand them to your employees. Additionally, you can add multiple company profiles, if needed, so that you can switch between them easily, without having to discard old data.
After you choose the preferred company profile, you can generate 1094-B, 1095-B, 1094-C and 1095-C forms by selecting the appropriate option from the Current Company tab.
Features backup support and allows you to import forms
Aside from the features described above, this application also provides you with backup support for company profiles, so that you can safely save sensitive information on your computer and restore it if needed. Furthermore, you can import form data from TXT, CSV or TAB files from your computer.
To sum it up, ez1095 is a lightweight application that allows you to generate, fill and print ACA 1095 forms easily. It comes with a minimalistic interface that integrates intuitive functions, which allows you to benefit from its abilities in a simple manner.
https://www.halfpricesoft.com/
yl63d.Halfpricesoft.ez1095.v12.0.3.7z.html
