04 de Abril de 2026, 10:05 *
Autor Tema: Cadence SPECTRE 25.10 (01.125) HF001 Linux  (Leído 52 veces)
« : 30 de Diciembre de 2025, 15:53 »
Free Download Cadence SPECTRE 25.10 (01.125) HF001 | 1.7 Gb
Cadence Design Systems, Inc. has released SPECTRE 25.10 (01.125) HF001 is an advanced circuit simulator that simulates analog and digital circuits at the differential equation level.
Owner:Cadence
Product Name:SPECTRE
Version:25.10 (01.125) HF001
Supported Architectures:x86_64
Website Home Page :www.cadence.com
Languages Supported:english
System Requirements:Linux **
Software Prerequisites:pre-installed Cadence XCELIUM Main 25.03
What's new in Spectre 25.10
Here are some of the important updates made in the SPECTRE 25.10 release
Spectre RF
-Spectre RF Option in Virtuoso Studio RF:The Spectre RF Option is now integrated with Virtuoso Studio RF to allow design and verification of silicon and multi-fabric RF or microwave designs.
-Load-Pull Analysis:With the integration of the load-pull analysis engine of Virtuoso Studio RF in Spectre RF, you can optimize RF and microwave designs with greater precision and efficiency.
-Harmonic Balance Tuner:A new element, harm_tuner, has been added in rflib to support harmonic load-pull and harmonic source-pull analyses. harm_tuner is based on the Microwave Office hbtuner3 element but has been customized for use with the Spectre RF Option.
Spectre Photonics
Spectre Photonics is a new solution for designing and analyzing photonic integrated circuits (PICs) and electronic photonic integrated circuits (EPICs). Built on the Spectre functionality, Spectre Photonics expands simulation capabilities to include analysis of photonic circuits within one simulation platform, thereby enabling native electronic photonic co-simulation functionalities.
Spectre FMC Analysis
The smart corners feature, which applies Spectre FMC Analysis worst-case samples analysis across multiple process, voltage, and temperature corners, has now been integrated with Virtuoso ADE Artist.
1669185 AMSD         Support S-parameter analysis in Spectre AMS Designer
2203965 AMSD         Support S-parameter analysis in Spectre AMS Designer
2554716 AMSD         Support S-parameter analysis in Spectre AMS Designer
2996001 AMSD         Support S-parameter analysis in Spectre AMS Designer
3132774 FX           In Spectre FX, Monte Carlo does not save the .meas data for the completed iterations
3153317 FX           Require parasitical rscale and cscale for specified net in postlayout simulation
3159694 FX           Spectre FX reports incorrect violation results when assert check is used
3170650 FX           Support an option to exclude VPN/NETCUT for the power-off option of the specified subcircuit
3175435 FX           Spectre FX error: Rigid branch loop detected
3176605 FX           Time accumulated for the digital engine is significantly high in a Spectre FX with Spectre AMS Designer case
2913791 SPECTRE      vrefbins and irefbins are reported incorrectly in the Spectre log file
3052408 SPECTRE      Support waveform compression for switching circuits
3120765 SPECTRE      if/else block with a topology change always retains unnecessary nodes and causes significant slowdown
3137841 SPECTRE      Verilog-A Editor Extraction Does Not Find an Incorrect Parameter in a Module Port List
3149662 SPECTRE      Transient simulation takes a very long time for DC convergence when running with +preset=mx +postlpreset=cx
3157677 SPECTRE      The pre_config option provides an incorrect net value for net in spectre.dc file
3159005 SPECTRE      Inverter array with multiplier giving inconsistent output with Spectre X
3159419 SPECTRE      Electrothermal - Copy the package and tech file information to the output directory
3162899 SPECTRE      Spectre py interactive commands .location and .isCont do not work as expected
3165310 SPECTRE      As additional fsdb database is generated when the netlist contains defwave and probe statements
3165752 SPECTRE      Error in Spectre if delay is used as a net name in vcvs
3167225 SPECTRE      EM current accuracy issue in Spectre APS EMIR and Voltus-Fi
3169577 SPECTRE      Thermal analysis results differ between various Spectre versions
3173876 SPECTRE      In a Monte Carlo/transient noise run, 'noiseseed' should be independent of 'numruns' when using 'mc_auto_noiseseed'
3174998 SPECTRE      Transient analysis with power measure statements takes longer in Spectre versions newer than Spectre 23.1 ISR8
3176192 SPECTRE      subckt of the top path instance is not found in the dspf file during the EMIR simulation
3180033 SPECTRE      pvcvs gives wrong answer if an input is small
3180406 SPECTRE      Error when SCA < 0 in bsim4 devices
3181767 SPECTRE      measoutput=detail required for measures to be evaluated correctly
3183764 SPECTRE      Binary format %b ignores the width specifier in $fstrobe function
3184621 SPECTRE      Multiple relxpert mode issues when using the +sfe option
3112372 SPECTRERF    pnoise taking too long to finish the simulation
3136293 SPECTRERF    Segmentation Fault while simulating RF mixer circuit
3138471 SPECTRERF    SP noise figure Description differs from the HB noise figure Description for the same netlist
3151877 SPECTRERF    Spectre exits unexpectedly when save=allpub and wildcards are used in the save statement
3177198 SPECTRERF    Results of the envelope analysis are incorrect when using sweep
3177276 SPECTRERF    HB analysis stops responding when xdp is not used, and enabling xdp leads to incorrect hbnoise results
Cadence Spectreis a high-performance circuit simulator used for analog, mixed-signal, and RF integrated circuit design. It's commonly used for verifying the performance of circuits before they are manufactured, allowing designers to identify and correct potential problems early in the design process. Spectre simulates circuit behavior, including voltage, current, and power consumption, under various operating conditions and process variations.
Co-Simulate with Cadence Spectre
This video demonstrates a new feature in AWR Design Environment V13 that provides the ability to co-simulate with Cadence Spectre designs.
Cadenceis a pivotal leader in electronic design and computational expertise, using its Intelligent System Design strategy to turn design concepts into reality. Cadence customers are the world's most creative and innovative companies, delivering extraordinary electronic products from chips to boards to systems for the most dynamic market applications.
ucmy2.Cadence-SPECTRE-25-10-01-125-HF001-Linux.rar.html
