06 de Abril de 2026, 19:18 *
Autor Tema: AnySQL Maestro Professional 16.12.0.20 Multilingual  (Leído 42 veces)
« : 31 de Diciembre de 2025, 07:26 »
Free Download AnySQL Maestro Professional 16.12.0.20 Multilingual Fast Links | 28.9 Mb
AnySQL Maestro is the premier Windows GUI admin tool for development and management of database databases. It allows you to make all the database operations easy and fast. Using AnySQL Maestro you can operate database objects, build queries visually, represent databases as ER diagrams, execute queries and SQL scripts, view and edit data including BLOBs, represent data as diagrams, compose OLAP cubes, export and import data to/from most popular file formats, and use a lot of other tools designed for the easiest and most efficient work with database server.
Easy database management
AnySQL Maestro allows you to create and drop databases quickly. Database profiles give you the opportunity to connect to databases in one touch and work with the selected databases only.
Powerful database object management
AnySQL Maestro provides you with an ability to manage database objects. For example, you can perform operations with a group of objects as well as with a single object in Object Manager, sort, group and filter the database objects within Object Browser, copy an object from one database to another by a drag-and-drop operation inside the explorer tree, use Windows clipboard to copy a set of objects and so on.
Working with tables and table subobjects
AnySQL Maestro wizards and editors allow you to create, edit and drop tables as well as their fields, indexes, and foreign keys in a couple of simple operations.
Building and executing queries
AnySQL Maestro provides two powerful tools which allow you either to edit query text directly with syntax highlighting and code completion or to build a query diagram visually selecting tables and fields, setting links between tables and so on.
Support of the latest database features
AnySQL Maestro works fine with any version of any database engine which is accessible via  ODBC driver or OLE DB provider.
Powerful data management tools
With AnySQL Maestro you can view and edit table data (including BLOB fields), export and import data to/from MS Excel, MS Access, DBF, XML, TXT, CSV and other formats, get SQL data dump and more.
Work with database metadata
AnySQL Maestro provides you with a number of tools for working with database metadata and SQL scripts, including code folding.
Full customization according to your preferences and needs
You can customize the software behavior, select a user interface scheme and set a lot of other preferences.
Operating System:Windows 7, 8/8.1, 10
https://www.sqlmaestro.com/
f0o6i.AnySQL.Maestro.Professional.16.12.0.20.Multilingual.rar.html
