Free Download Conversations (Jabber XMPP) v2.19.8 build 4216404 | Android | 24.3 MBPaid version
A free and open source Jabber/XMPP client for Android. Easy to use, reliable, battery friendly. With built-in support for images, group chats and e2e encryption.
Design principles- Be as beautiful and easy to use as possible without sacrificing security or privacy
- Rely on existing, well established protocols
- Do not require a Google Account or specifically Google Cloud Messaging (GCM)
- Require as little permissions as possible
Features- End-to-end encryption with either OMEMO or OpenPGP
- Encrypted audio and video calls (DLTS-SRTP)
- Sending and receiving images
- Intuitive UI that follows Android Design guidelines
- Pictures / Avatars for your Contacts
- Syncs with desktop client
- Conferences (with support for bookmarks)
- Address book integration
- Multiple Accounts / unified inbox
- Very low impact on battery life
XMPP FeaturesConversations works with every XMPP server out there. However XMPP is an extensible protocol. These extensions are standardized as well in so called XEP's. Conversations supports a couple of those to make the overall user experience better. There is a chance that your current XMPP server does not support these extensions. Therefore to get the most out of Conversations you should consider either switching to an
XMPP server that does or - even better - run your own XMPP server for you and your friends.
System Requirements:Requirements: Android 6.0+
https://play.google.com/store/apps/details?id=eu.siacs.conversations&hl=en
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatord6v0t.Conversations.Jabber...XMPP.v2.19.8.build.4216404.rar.htmlDDownloadd6v0t.Conversations.Jabber...XMPP.v2.19.8.build.4216404.rarFreeDLd6v0t.Conversations.Jabber...XMPP.v2.19.8.build.4216404.rar.htmlLinks are Interchangeable - No Password - Single Extraction
