07 de Abril de 2026, 04:05 *
Autor Tema: inCarDoc Pro OBD2 v8.0.0 build 15272  (Leído 79 veces)
« : 01 de Enero de 2026, 18:59 »
Free Download inCarDoc Pro   OBD2 v8.0.0 build 15272 | Android | 18.3 MB
Pro version
inCarDoc Pro - best doctor for your car: Check Engine codes reader, diagnostics, scanner, monitor and logbook tool: reads real-time and stored diagnostics parameters from ECU of OBD-II compliant cars.
Car diagnostics
- Works as fault codes OBD2 scanner, reads Check Engine (MIL) state, details, related freeze frame data, finds descriptions and clears stored diagnostic trouble codes (DTC). Allows to store and share diagnostics data when looking for a professional service/repair assistance. Please note that app supports only parameters and ECU's specified with OBD-II standard, that is Engine and Emission systems.
Real-time parameters
- Reads real-time engine and vehicle OBD2 parameters PIDs from car's sensors: speed, rotation (rpm), coolant temperature, pressure, O2 oxygen sensors and multiple other PIDs. Available chart drawing and analog/digital widgets presentation. Please note that exact list of scanned OBD2 parameters depends on your car make/model/year.
Economizer
- Trip Computer mode for presenting and tracking car's fuel economy/consumption. Presents both in-drive (instant and average MPG) as well as per trip, per day and other statistics. Please note, that feature available when appropriate OBD2 economy parameters (MAF or MAP+IAT+RPM) are supported in your car. For correct calculations you may need to enter Engine displacement (in cubic cm) and volumetric efficiency (in %, the default is 80).
Other features
- logbook notes: fueling, service records, car maintenance, diagnostics
- GPS parameters: speed, altitude
- register and upload data to web
- console mode: for advanced users, direct OBD2 and ELM327 commands sending
- use custom configurations for non-standard parameters and protocols
Avoid!!! simultaneous running of multiple OBD-II reading apps, be sure that other apps does not keeping live Bluetooth/WiFi connection via ELM327 OBD2 scanner.
Required permissions
- Device & app history
Used to self- identify application when at background
- Location
Extra GPS parameters: GPS speed, altitude, position for fueling and service search
- Photos/Media/Files
Store and read "Logbook" and Debug data as direct user's actions
Requirements: Android 6.0+
https://play.google.com/store/apps/details?id=com.pnn.obdcardoctor_full&hl=en
18elr.inCarDoc.Pro...OBD2.v8.0.0.build.15272.apk.html
