Free Download XtraTools Professional 26.0.1 Multilingual Fast Links | 3.4 MbXtraTools an universal tool for optimizing the MS Windows system that takes care of all aspects of your computer - from optimizing the registry and removing unnecessary programs to setting up network connections and increasing the speed of RAM. It is a compact tool with an intuitive interface that gives you complete control over the startup process, memory monitoring, and a huge set of system settings that control your computer. The current version of the software offers the following tools: Scan Folders, Scan Files, Scan Registry, Startup Manager, System Tweaker, Xtra Start, System Monitor.
XtraTools: Monitor
Used to monitor the MS Windows operating system CPU and RAM usage and control the state of folders, files and registry of the system.
XtraTools: Xtra Start
An easy-to-use tool that is used to easily scan and clean folders, files and registry of the MS Windows operating system.
XtraTools: Scan Folders
Used for periodic cleaning of temporary folders of MS Windows operating system. Not deleted files in temporary folders slow down the access time to files on the hard disk.
XtraTools: Scan Files
XtraTools: Scan Registry
XtraTools: Startup Manager
This tool allows you to monitor, add, remove, enable and/or disable individual startup items. Adjust applications initialized during the loading process of the operating system.
XtraTools: Tweak PC
XtraTools: Objects Eraser
Removes traces of activity on your computer. Cleans the history of started programs, search history, history of last opened documents and history of various Internet browsers.
XtraTools: File Encryptor
Designed for fast processing of extremely large files. It can encrypt or decrypt files, contents of folders and have flexible user interface with detailed messages about all operations.
Minimum system requirements:OS: MS Windows 11/10/8.1/8/7/VISTA x86 x64
32 MB free disk space
256 MB RAM
https://www.xtratools.com/
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgator2yue0.XtraTools.Professional.26.0.1.Multilingual.rar.htmlDDownload2yue0.XtraTools.Professional.26.0.1.Multilingual.rarFreeDL2yue0.XtraTools.Professional.26.0.1.Multilingual.rar.htmlLinks are Interchangeable - No Password - Single Extraction
