04 de Abril de 2026, 20:11 *
Autor Tema: Video Converter, Compressor v17.0.7  (Leído 52 veces)
« : 04 de Enero de 2026, 21:44 »
Free Download Video Converter, Compressor v17.0.7 | Android | 72.4 MB
Premium version
Fastest Video Converter and Compressor in the market that supports almost all video formats: MP4, MKV, AVI, 3GP, MOV, MTS, MPEG, MPG, WMV, M4V, VOB, FLV etc.
This converter & compressor supports converting, compressing, changing resolution, Frame rate(FPS), bitrates of a video file. It can also convert video files into Audio formats like MP3, AAC, AC3, OGG, M4A, WAV etc.
This video audio editor app also lets you trim/cut both audio and video as well as merge your audio and video files.
Key features
Video Converter
- Convert and Compress your video to almost any video and audio formats.
- Supported Formats: MP4, MKV, AVI, 3GP, FLV, MTS, M2TS, TS, MPEG, MPG, WMV, M4V, MOV, VOB, F4V, WEBM, DAV, DAT, MOVIE, MOD, MXF, LVF, H264.
- Resolution: Choose from predefined 4K resolution to 240P or put any custom resolution.
- Frame Rate: Choose from any predefined frame rates or put any custom frame rate.
- Subtitle Track: Choose from existing subtitles tracks of the video or upload subrip, mov_text, srt, webvtt, vtt format subtitles.
- Audio Track: Choose from existing audio tracks of the video to keep or add external audio tracks of mp3, aac, m4a, wav formats.
- Video & Audio Codecs: We support h264, mpeg4, mpeg1, mpeg2, flv1, vp8, vp9, wmv1, wmv2, aac, mp3, mp2, ac3, opus, vorbis, flac, alac, wmav1, wmav2 video and audio codecs.
Rotate & Flip Video: Apply 90 degree clockwise/anticlockwise or 180 degree rotation and Flip videos vertically or horizontally.
Compress option
- High Quality: This compression option uses X264 codec to compress your video keeping nearly original video quality.
Video Bitrate: Reset video bitrate to compress the video to a specific .
Video Merger
- Join/merge/concat multiple videos into one video in sequential, Top-Bottom or Side-By-Side style.
Video Cutter
- Cut and trim your video files. You can input the exact starting and ending cutting time precise to the milliseconds.
Cut Video: This option keeps part of the video you selected.
Trim Video: This option removes the selected part of the video if you enable the REMOVE SELECTED switch.
Video to Audio
- Convert videos to almost any audio format and also compress the audio.
- Supported Formats: MP3, M4A(AAC), AC3, WAV, OGG, FLAC. MP4, MKV, AVI, 3GP, FLV, MTS, M2TS, TS, MPEG, MPG, M4V, MOV, VOB, F4V, WEBM, WMV, DAV, DAT, MOVIE, MOD.
Audio Cutter
- Cut and trim your audio files. You can input the exact starting and ending cutting time precise to the milliseconds.
- Cut Audio: This option keeps part of the Audio you selected.
- Trim Audio: This option removes the selected part of the audio if you enable the REMOVE SELECTED switch.
- Audio Bitrate: Choose any audio bitrate while saving your cut audio.
- Output Format: MP4, MP3, M4A(AAC), AC3, WAV, OGG, FLAC.
Audio Converter
- Convert and Compress your audio to almost any audio format.
- Supported Formats: MP3, M4A(AAC), M4B(AAC), AC3, WAV, OGG, FLAC.
- Channel: Choose between mono and Stereo channel.
- Compress Section
- Encoding: We support both Constant Bitrate(CBR) and Variable Bitrate(VBR) encoding.
- Sample Rate: You can choose sample rate from 8K to 48K.
Audio merger
- Merge almost any format Audios to any other format. We support MP3, M4A(AAC), M4B(AAC), AC3, WAV, OGG, FLAC files as input and output formats.
Batch Processing
- Users can queue multiple files for processing. All our features support Batch processing.
Requirements: Android 8.0+
https://play.google.com/store/apps/details?id=com.inverseai.video_converter&hl=en
doasr.Video.Converter.Compressor.v17.0.7.rar.html
