06 de Abril de 2026, 10:54 *
Autor Tema: Lyric Video Studio 1.4.12  (Leído 90 veces)
« : 05 de Enero de 2026, 23:50 »
Free Download Lyric Video Studio 1.4.12 | 263 MB
Turn your lyrics into stunning visuals - effortlessly. Lyric Video Studio is your go-to app for creating powerful, professional-looking lyric videos without the hassle. Whether you're a musician dropping a killer new track, a content creator, or just playing with visuals, this app lets you sync lyrics to your music in just a few clicks. Import your lyrics, drag to sync, and you're good to go. You know your lyrics - now show them off.
- Optimized for lyric videos, music videos and visualizers, but capable of anything.
- Non-linear video editing with AI image and video sources, 4K support.
- Easy and fast lyric import, text editing / subtitling made easy.
- Generate video content with 3rd party providers, Large language model support.
- Run image models locally, Keep your prompts organized.
- Fragment Shader support.
- Object detection and motions tracking for videos.
3rd party plugin support!
A1111 (localhost), SD3, OpenAi Dall-E 3, Black Forest labs, Luma Labs Dream Machine, Runway ML, MiniMax and KlingAi. Create a storyboard for your video! Or the whole video! Prompt images and videos using your service of choice and turn them easily to videos within the app. One app to rule your prompts!
Create start frames for video plugins to generate content. Create videos using text prompt. Or just import your video and add subtitles to it. Turn lyrics to video storyboard with just a few clicks!
Easy video editing
You don't need to be professional video editor to use this app (but you can be Sonrisa ). DAW-like horizontally scrolling multi-track timeline, familiar from all digital audio workstations, is used to keep track of you items. Lyric, video, audio, primitive and generative AI tracks, as many as you want and need, keeping mind you PC performance. Includes integrated library for video import & export and also support using FFMPEG optionally. This is the video maker rethought from the scratch!
Effects and transitions
Apply effects on project and track level, affecting all 'child' items: fast and easy way of creating consistent transitions to your video very fast. Apply effects also to items to mix things up a little bit. Animate all the variables editable, like for example font color gradient offset or color. Mass edit multiple items! This video tool is designed with mindset to stop you from copy-pasting effects, transitions and font settings between items and make iteration of ideas faster. Also supports Fragment shaders, plenty as built in and you can add yours also.
Iteration is the key for getting the right results with generative AI. Lyric Video Studio keeps all your generations and results safe and you can swap between different variations easily. Create AI videos with help of multiple service providers.
Track objects, remove backgrounds
Latest addition adds motion and object tracking. Backgrounds can be removed from videos and images. You can attach items, including fragment shaders, to objects in video.
Add lyrics to your existing video
Import your lyrics from text file and app will add them in initial layout that is easy to sync with the song. Just 'arm' the track just like you do when recording fast keyboard solos, press rec and keep 'Sync' button pressed whenever a word or phrase is in the right place. Don't worry if you missed a beat, you can continue where ever you want or just fix the timing manually. This lyric video creator was made to make adding text to videos easy and fast! Now also includes audio-to-text feature! Extract text from audio and automatically align with the video.
LLM's, at your service
Large Language Models are supported to transfer your lyrics to video ideas and prompts. With just few clicks, you can export lyrics as image/video prompts. But which models to choose? Where do I get it? Don't worry, the app has curated & tested list with download button option.
Optimized, to the last drop
Your rig does not need to be of a high end. Memory usage is optimized to enable even lower end computers to make videos. You do have a beast of a machine? Well, the app will certainly make use of your HW as much as possible Sonrisa Local Stable Diffusion support for machines with NVIDIA 30xx or better (40xx series recommended).
Traditional, but advanced
This music video maker offers traditional video editing controls and effect but also allows you to generate content from 3rd party services. So not just another AI video editor, but a hybrid! Gives you the control of the video. Edit your clips! Master your prompts! Create music videos. Create lyric videos. Create all kind of videos with ease!
Easy of use in mind
App is optimized to be fast and easy to use. Forget the pain of applying same effect to multiple items. Changed you mind? Need to do the exact same thing again to 100+ items? Not with Lyric Video Studio. This lyric video maker is built to reduce your clicks With presets for lots of features, you can store your favorite setups easily.
Alternative European
Lyric Video Studio is developed in Finland, EU. This video creator is the alternative to Adobe Premiere, DaVinci Resolve, Avid Media Composer etc.
AI Lyric Video Maker | Fast Subtitling for Musicians
Create stunning lyric videos easily! Lyric Video Studio helps musicians craft AI-powered, professional lyric videos with plugins, subtitles & full customization.
Bring Your Lyrics to Life | AI Lyric Videos Made Easy
Turn your songs into stunning visual stories! Lyric Video Studio blends AI magic with artistic control - perfect for indie musicians and creative souls.
System Requirements
Windows 10 version 17763.0 or higher (64-bit)
* Min requirements for Full HD video, no local AI: 2ghz processor, 8GB memory, SSD, windows 10. 3Ghz cpu, 16GB RAM, NVIDIA RTX 30xx recommended for local AI features
https://lyricvideo.studio/
yzh5d.Lyric.Video.Studio.1.4.12.rar.html
