05 de Abril de 2026, 19:41 *
Autor Tema: Drive SnapShot 1.50.0.1816 Portable  (Leído 50 veces)
« : 06 de Enero de 2026, 21:31 »
Free Download Drive SnapShot 1.50.0.1816 Portable Fast Links | 17.12 MB
Drive Snapshot creates an exact Disk Image of your system into a file, including the operating system, installed programs, your data and all security attributes - while windows is running and you continue to work. Drive Snapshot it allows you to backup your partition or your hard disk drive and it also can create a disk image of your system. If disaster strikes (a virus, trojan, or hard disk crash), a complete and exact restauration of your system will be possible in only few minutes. The image file can be mounted as a virtual drive, so you can easily restore (or use) single files or directories, using the Windows Explorer, or other program.
Here are some key features of "Drive Snapshot":
* Create Disk Image Backups, while running Windows
* There is no restart (to DOS) necessary. Never.
* Continue your work, while the Backup is in progress
* The new Snapshot technology ensures, that all data are consistent, and reflect the PC's data at the start of backup. There are no difficulties with opened files. Never.
* This enables a very fast and easy way to backup servers and other computers, that must run 24 hours a day.
* Easy Use and Restore of single Files or directories
* Drive Snapshot creates a virtual drive, containing all your drives data. You may use, compare, or restore these files directly from the Disk Image file.
* This works with any program of your choice, including (of course) the Windows Explorer
* Complete Restore of a disk in case of Disaster
* If a disk is restored to it's original state, it will be exactly the same as at the time of Backup - byte for byte.
* Restoring a system partition will require DOS; other drives can be restored using Windows
* Compatible to all Windows file systems (FAT16, FAT32, NTFS)
* Compatible to all Windows RAID Methods
* Very easy and comprehensive command line interface
* This makes automation of regular tasks a breeze.
System requirements:
Windows 2000, XP, Vista, 7, 8, 8.1, 10, 11, 2003 Server, 2008, 2008 R2, 2012, 2016, 2019, 2022, PE, Windows-X64
3 MB disk space + space to save the disk images.
32MB RAM if active, 0 MB if not active.
You need administrative rights to execute Drive Snapshot
Home Page-http://www.drivesnapshot.de/
y9vjy.Drive.SnapShot.1.50.0.1816.Portable.zip.html
