07 de Abril de 2026, 04:05 *
Autor Tema: AnalogX Genesis Pro v2.0.0 Beta (Win/macOS)  (Leído 41 veces)
« : 07 de Enero de 2026, 07:15 »
Free Download AnalogX Genesis Pro v2.0.0 Beta (Win/macOS) | 293/133.8 Mb
Genesis Pro v2.0 Beta is the most advanced version of our flagship engine to date. Built from the ground up to support GPU graphics card acceleration, the new Genesis Pro unleashes a level of power, speed, and workflow freedom that simply was not possible before.
At its core lies our updated AnalogX engine faster, cleaner, and more efficient allowing you to run more models whether you are using Genesis Core CPU or the new Genesis Pro platform CPU and GPU. Every part of the system has been refined from metering to browsing to calibration, bringing the entire user experience closer to real analog mixing while staying fluid, and modern.
What's New in Genesis Pro v2.0 Beta
GPU Capability
Run high quality Genesis models directly on your GPU and free your CPU for instruments, reverbs, and production workflows. Experience next level performance with the worlds first true GPU powered analog mixing ecosystem. Minimum system requirements available on our website.
Core Engine Upgrade
The new core delivers optimised efficiency and the ability to run more models simultaneously on both Genesis Core CPU only and Genesis Pro CPU and GPU capable.
Sweet Spot Meters
Two new sweet spot LED meters one above the input gain and one above the red drive section help you dial in perfect gain staging every time.
Gain Reduction Meter
Real time compression and THD monitoring in development gives you immediate visual feedback of dynamic behaviour across models.
Input Pre Post Monitoring
A dedicated Pre Post switch allows true input and output metering allowing you meter the signal arriving PRE Genesis or POST the Genesis input gain stage.
New Slot Matrix
A cleaner and more accurate slot matrix featuring aligned input and output meters for faster visual assessment and easier chain management.
Auto Updating Peak Metering
Peak metering dynamically updates to reflect real time signal level changes with greater precision.
Re Aligned Meter Calibration
All meters now follow a full scale dBFS calibration matching the levels that our emulations are designed for. This ensures you have the perfect guide to gainstage every model exactly as intended.
Improved Library Browsing
Browse all AnalogX libraries in a cleaner, faster, more intuitive layout making your workflow smoother and session speed significantly faster.
Integrated PDC
Plugin Delay Compensation is now built in and reports correctly to the DAW. Tested in Ableton Live 12 Cubase 15 Reaper Logic Pro Pro Tools and Bitwig.
Wet Dry Phase
Wet Dry blend is now perfected for HQ and STD models ensuring phase accurate parallel processing.
Older model formats may work but are not guaranteed, however we will continue to add the older models to Genesis
https://analogx.co.uk/GPU
nkm8r.AnalogX.Genesis.Pro.v2.0.0.b.dmg.html
nkm8r.AnalogX.Genesis.v2.0.0.b.rar.html
