Free Download Speed test 4G 5G WiFi & maps v2.15.24 build 21524001 | Android | 19.3 MBPremium version
More than a simple speed test, nPerf brings you the best and the fullest mobile connection quality measurement tool up to 1 Gb/s speeds!
- Full QoS test: In few seconds, test your bitrate speed, latency, browsing speed and video streaming quality on your mobile device.
- Comparison function: Compare your results with those of others users and for each provider with a real time barometer.
- Interactive map: Check network coverage and carriers performances in your area (in USA : AT&T, Sprint, T-Mobile, Verizon Wireless).
- Network monitor: Stay informed on data speed in real time on the top of your mobile screen (status bar). Reports your data plan usage (in notifications).
A sliding menu (hamburger icon on top left corner) allows you to start every test separately
- Speed test
- Browsing test - website loading speed
- Streaming test
All your results are saved in an history with all tests locations on a map. Easily share your results on social networks with nPerf sharing pictures which present a useful summary of your test. Customize your application by switching the background theme using the Settings.
nPerf relies on an homemade top technology and a wordwide high speed servers network which can deliver the bitrate you need for speed tests. With nPerf, you do not blow up your data plan: with many optimizations, testing consumes up to 2 times less data than competing speed tests. In addition, a data indicator will notify you if the monthly threshold you can set in the menu Settings is exceeded.
All connection types can be tested over 1 Gb/s speeds!
2G, 3G, 4G, 5G, Wimax, WiFi & Ethernet speed test.
All WiFi technologies are supported. WiFi 802.11 a/b/g/ac dual-band, tri-band & quadri-band
All LTE technologies are supported. LTE, LTE Advanced dual-band, tri-band & more
3G / 4G / 5G coverage & speeds maps
- USA: AT&T, Sprint, T-Mobile, Verizon Wireless.
- Canada: Bell, MTS, Roger Wireless, Videotron, SaskTel, Telus, WIND.
- Malaysia: CellCom, DiGi, Maxis, U Mobile.
- Singapore: MobilOne, SingTel, Starhub.
and many more countries all over the world!
Test your connection, diagnose connectivity issues and keep your Internet service provider and carriers honest!
System Requirements:Requirements: Android 5.0+
https://play.google.com/store/apps/details?id=com.nperf.tester&hl=en
Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgator4zwbk.Speed.test.4G.5G.WiFi..maps.v2.15.24.build.21524001.apk.htmlDDownload4zwbk.Speed.test.4G.5G.WiFi..maps.v2.15.24.build.21524001.apkLinks are Interchangeable - No Password - Single Extraction
