05 de Abril de 2026, 22:53 *
Autor Tema: ASDIP Wood 3.3.2.2  (Leído 50 veces)
« : 12 de Enero de 2026, 14:21 »
Free Download ASDIP Wood 3.3.2.2 | 8 Mb
ASDIP Wood is a structural engineering software utilized by engineers for the design of wood members, such as biaxial columns, continuous beams, and out-of-plane bearing walls.
This structural design software is based on the latest NDS provisions. Load combinations as per ASCE 7 and CSA A23.3. ASDIP WOOD substantially simplifies time-consuming calculations for structural engineering design.
Key Benefits of ASDIP WOOD
Quickly model your concrete members with the simple and efficient graphical user interface.
Confidently optimize your design and comply with design code provisions.
Impress clients and plan-checkers with professional condensed or detailed reports.
Extensive documentation, solved examples, and blog posts to guide you throughout the software.
Create, organize, manage, and store your electronic calculations safely.
Key Design Features:
Wood Columns - rectangular or round column cross sections
Wood Beams - rectangular, T-beam, spandrel, inverted-T, or L-beam cross sections.
Wood Bearing Walls - Equally spaced studs with vertical loads and out-of-plane wind.
Dead, Live, Roof live, Snow, Wind and Seismic Loads
Graphic display of 2D and 3D interaction diagrams in columns and walls.
Built-in databases for section and material properties from NDS code.
Easily select either Sawn lumber, Glued Laminated, or Composite Lumber sections.
https://www.asdipsoft.com/asdip-wood
y88cz.ASDIP.Wood.3.3.2.2.rar.html
