05 de Abril de 2026, 22:45 *
Autor Tema: SDF Viewer 2.0.3  (Leído 47 veces)
« : 12 de Enero de 2026, 14:22 »
Free Download SDF Viewer 2.0.3 | 98 Mb
SDF Viewer - A smart and handy tool, powerful enough for database professionals, yet easy to use and available at an affordable price. Create, view and edit SQL Server Compact Edition (SQLCE) version 3.1, 3.5 and 4.0 databases.
Features
Runs on Windows 7 SP1, 8, 10 and 11
Works with SQL Server CE Version 3.1; 3.5 and 4.0 databases - Auto Detection of Database Versions
Does not require MS SQL Management Studio or Visual Studio
Copies Database Files to and from your Windows Mobile Device
Opens .SDF Database file on your PC
Build SQL statements visually with the Query Builder
Work with Parameter Queries
Creates New SQL Server Compact Edition Databases
View the Database and Index Structures
Create a New Tables, Rename, Drop or Modify Existing Tables
Add, Delete, Rename, Re-Order and Alter Data Columns
Create New Indexes and Rename Existing Indexes
Add Single and Multiple Foreign Key Relationships
Rename Existing Relationships
View, Sort, Add, Modify and Delete Data from Tables
View, Add, Rename and Change Image Columns
Create SQL Queries and Scripts, Drag & Drop Table and Column Names to Query
Open/Save/Run Scripts/Queries as *.sqlce files
Create Difference Scripts between two sqlce databases for structure and data
Add, Change and Remove Database Passwords
Compact and Repair Databases
Upgrade Existing Databases to higher versions
Import and Export Tables to Excel XLS and XML formats
Import From SQL Server and SQL Server Express
Import From MS Access
Import Pictures into a Database
Script SQLCE Database Tables, Data, Indexes
Create SQLCE Database Diagrams
Set an automatic backup of database files each time they are opened
https://www.flyhoward.com/SDF_Viewer.aspx
xwrkc.SDF.Viewer.2.0.3.rar.html
