06 de Abril de 2026, 13:00 *
Autor Tema: VovSoft SVG Converter 1.5  (Leído 37 veces)
« : 14 de Enero de 2026, 13:18 »
Free Download VovSoft SVG Converter 1.5 | 11.9 Mb
SVG is the extension of vector graphic files that contain scalable images. This image format is XML based. It supports animation that can contains vector graphics, raster graphics, and text. It contains data using lossless data compression algorithm. SVG files can be edited using drawing software as well as text editors.
Batch SVG Converter
Convert scalable vector images to PNG, WEBP, JPEG, BMP, HTML or PDF with Vovsoft SVG Converter! Conversion preserves transparency (when possible) and allows you to scale lossless to any specify size. You can enter any width and height in pixels. This software also allows you to create black and white pictures using "Convert to grayscale" option.
This mass SVG convertor utility is a very easy to use tool for your laptop or desktop computer. There are a lot of online websites that can convert SVG images. However they have upload limitations. Vovsoft SVG Converter can convert images as many as you want through a user-friendly interface. You can easily create PNG, WEBP, JPG, BMP, HTML or PDF files by selecting the input SVG files in bulk. The application will do the rest for you.
The best part of the program is that the conversion is done completely offline. You are the only controller of your private data. No image file is sent to internet in any case.
Operating System:Windows 11, Windows 10, Windows 8/8.1, Windows 7, Windows Vista (32-bit & 64-bit)
https://vovsoft.com/software/svg-converter/
dh4n0.VovSoft.SVG.Converter.1.5.rar.html
