05 de Abril de 2026, 16:55 *
Autor Tema: PassFab 4EasyPartition 3.9.2.19 Multilingual  (Leído 36 veces)
« : 14 de Enero de 2026, 13:18 »
Free Download PassFab 4EasyPartition 3.9.2.19 Multilingual Fast Links | 34.7 Mb
PassFab 4EasyPartition helps to clone one disk/partition data to another disk/partition intact without losing any data on all Windows-supported PCs.
The most secure and professional system migration and partition management tool
- Quickly and safely migrate your Windows system to other hard disk or PC.
- 1-click to move to a new high-speed SSD, make your Windows boot faster.
- Upgrade to a larger hard drive, free up your disk space.
- Easily clone disks/partitions to create full backups, saving your time and efforts.
- Quickly resize, create, delete, split, and format partitions, simplifying your PC disk management.
Smart Disk & Partition Cloning
- Clone Disk
Want to recover data? Want to upgrade your drive? PassFab 4EasyPartition helps you to clone HDD, SSD, USB flash drive and other types of hard drive and transfer all the saved data & applications to the new drive.
- Clone Partition
Running out of disk space? PassFab 4EasyPartition enables you easily upgrade/replace/backup hard drives and transfer large amounts of data from one partition to another.
One-Click System Migration
Hunting for an easy-to-use tool to migrate your data, operating system and applications to other hard drives? PassFab 4EasyPartition is the best choice for you with just one-click, without requiring you to reinstall your operating system or applications!
- Migrate OS to SSD/HDD
Safely and easily migrate your data, OS and applications to another hard drive without data loss.
- Upgrade to a New High-speed SSD
Replace HDD with SSD, providing you with the easiest and fastest way to boot.
- Safely Transfer Everything
Ensure no business interruption when user migrate system to a more efficient OS. no need to install applications, system configuration file and other files as well.
- No Need to Reinstall the System
Transfer data directly without reinstalling the app. Improve efficiency and save your time.
The Best Partition Manager to Simplify Your PC Disk Management
PassFab 4EasyPartition simplifies disk partition management and maximizes your hard drive space, letting you resize, create, and split partitions without data loss. Perfect for beginners and designed for efficiency!
- 1-Click Resize Partition
Running low on disk space? Want to expand your partition? PassFab 4EasyPartition helps you to freely resize/move partitions and to maximize disk space usage.
- Create/Delete Partition Safely
Want to create/delete partitions on Windows? PassFab 4EasyPartition helps you to create a new partition from blank and existing ones or safely delete them.
- Change Driver Letter Quickly
PassFab 4EasyPartition provides a fast way to change driver letter according to your preference, so that you can access to your folders and files more accurately.
- Split Partition Easily
Divide a large partition into smaller partitions, enabling you to create multiple partitions for storing data in different categories.
Operating System:Windows 11/10/8.1/8/7
https://www.passfab.com/products/partition-manager.html
mr7yt.PassFab.4EasyPartition.3.9.2.19.Multilingual.rar.html
