Free Download EasyUEFI Technician 6.2 (x64) Multilingual Fast Links | 17.9 MbHasleo EasyUEFI is a handy and useful software that allows you to manage (U)EFI boot options, BCD boot options and EFI System Partition (ESP), it can help you repair Windows boot issues caused by corrupted or missing (U)EFI boot option, BCD boot option or EFI System Partition.
Hasleo EasyUEFI supports the creation of WinPE emergency disks, so you can boot from the WinPE emergency disks to fix issues caused by damaged or missing UEFI boot entries, BCD boot entries, or ESP when your Windows fails to boot.
Manage (U)EFI/BCD Boot Options & EFI System Partitions & Fix (U)EFI/BCD Boot Issues
- Comprehensive (U)EFI boot option management functions, such as create, delete, edit (U)EFI boot options, change (U)EFI boot sequence, etc.
- Comprehensive BCD boot option management functions, such as create, delete, edit BCD boot options, change default boot entry, etc.
- Backup, restore, rebuild, delete, explore, read and write EFI System Partition (ESP) or move EFI System Partition (ESP) to another drive.
- Creation of Windows PE emergency disk and command line support
- Supported OS: (U)EFI-based Windows 11/10/8/7/Vista/2022/2019/2016/2012/2008.
Key Features(U)EFI boot option management
This feature allows you to easily manage (U)EFI boot options, such as create, delete, edit, clean up, backup and restore boot options, or change boot sequence, all these operations done under Windows without entering BIOS setup.
This feature allows you to easily manage BCD boot options, such as create, delete, edit, set default boot option, backup and restore boot options, or change display order.
EFI system partition (ESP) management
This feature allows you to effectively manage the EFI System Partitions, such as backup, restore, rebuild, delete, explore, read and write the EFI System Partition, or move EFI System Partition from one drive to another.
Home Page -Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorh10c0.EasyUEFI.Technician.6.2.x64.Multilingual.rar.htmlDDownloadh10c0.EasyUEFI.Technician.6.2.x64.Multilingual.rarFreeDLh10c0.EasyUEFI.Technician.6.2.x64.Multilingual.rar.htmlAlfaFilehttps://alfafile.net/file/AdzMv/h10c0.EasyUEFI.Technician.6.2.x64.Multilingual.rarLinks are Interchangeable - No Password - Single Extraction
