05 de Abril de 2026, 22:45 *
Autor Tema: Siemens DesignCenter NX 2512.3002 (NX 2512 Series) Win x64  (Leído 68 veces)
« : 15 de Enero de 2026, 00:59 »
Free Download Siemens DesignCenter NX 2512.3002 (NX 2512 Series) | 18.5 Gb
Languages Supported: English, 中文, Čeština, Español, Français, Deutsch,
Italiano, 日本語, 한국어, Polski, Português, Русский
Siemens Digital Industries Softwarehas released Designcenter NX 2512.3002 (NX 2512 Series) is software solution developed to enhance digital engineering and collaboration throughout the lifecycle of your engineering projects.
The latest release of Designcenter NX isn't an incremental update; it's a strategic investment in digital transformation. This update introduces significant enhancements in AI-driven automation, web editing, immersive engineering, and enhanced collaboration tools for both design and manufacturing workflows.
Owner:Siemens Digital Industries Software
Product Name:Designcenter NX
Version:NX 2512.3002 (NX 2512 Series)
Supported Architectures:x64
Website Home Page :www.plm.automation.siemens.com
System Requirements:Windows *
What's new in Designcenter NX 2512.3002
2D Manikin enhancements for two-wheelers
You can now specify how to position the feet of a rider on a two-wheeled vehicle. This helps you design rider postures more accurately in compliance with the JASO T006 standards. Use the new Pedal Type list to select from two pedal type options: Floor or Peg. When you choose the Floor option, Designcenter defines the position of the rider's feet using the Accelerator Heel Point (AHP) and the shoe plane angle. When you choose the Peg option, Designcenter uses the Foot Rest Peg Point (FPP) and Toe Pedal Point (TPP) coordinates to position the rider's feet accurately. This flexibility allows you to define a 2D manikin for two-wheelers, such as scooters with floor pedals and motorcycles that have footrests that look like pegs. Designcenter now automatically computes the value of neck angle for both JASO standard rider sizes and user-defined custom sizes and displays it in the 2D Manikin wizard. For standard JASO sizes, Designcenter optimizes the neck angle automatically. When you create custom rider sizes, you can modify the value of computed neck angle if needed.
Eyellipse enhancements
Designcenter now automatically calculates the value of the neck angle. In the output, Designcenter now generates a grip point (G-Point).
For vehicles of all classes:
-    Designcenter automatically calculates the neck angle. You can view this value in Information Window. The Neck Angle option, which was previously used to specify the neck angle, is now removed from the Vehicle Parameters page of the Eyellipse wizard.
-    In the output, Designcenter generates a G-Point for the JASO T005 standards. Designcenter displays this point for vehicles of Class 2W and hides it for vehicles of all other classes.
Close
Rotation support for cableway patterns and space reservations
Starting withMechanical Routed System Designer 2512.3000, the Cableway Pattern command will include orientation controls for rectangular patterns and space reservations. These options let you dynamically rotate an entire multi-tier pattern as a rigid block while applying it to an Electrical Topology Path (ETP). In addition, when you apply standalone space reservations to an ETP, you can individually adjust the orientation of each reservation.
Note: Use the Reposition Orientation Control option to reposition the orientation controls on one or more paths. The order in which the option cycles the orientation controls is based on the XYZ coordinates of the path origins, starting from the lowest to the highest XYZ value.
Capital 3DE integration with Electrical Routed System Designer
The Electrical Routed System Designer application can be coupled with the Capital 3DE interface. You can install and interact with the Capital 3DE application within the context of Designcenter to view, analyze, and annotate Capital wiring designs in a 3D environment.
Close
This enables Capital design engineers to collaborate with Designcenter engineers by exposing Capital wiring integrator capabilities like Design Tree, Routing Assistant, Back Annotate, and Harness Management inside Electrical Routed System Designer, wherein Capital supplies all the electrical connection algorithms for a 3D model design.
Project objectives
These are some key project objectives:
-    Allow Capital to use 3D routing spline information to derive paths with 3D constraints.
-    Identify all harness data available for selection as part of the comprehensive routing context to determine which harnesses are needed to build a platform.
-    Allow cross-probing between the Capital data and 3D objects in the Designcenter graphics window.
-    Collect PLMXML, HX2ML, and all required metadata for each harness assembly.
-    Identify when a 3D harness topology is modified and needs to be updated in the Capital data model.
-    Establish design rules and actions that trigger an update in the Capital harness design.
The overall objective is to mesh the Capital 3DE interface with the Designcenter user interface so users feels like they are working within one seamless application.
New Designcentercustomer defaults
The following customer defaults are provided for running the Capital add-on in Electrical Routed System Designer:
-    Activate Capital at Startup
-    determines whether the Capital add-on automatically starts when you launch a Designcenter session.
-    Capital Install Location
-    specifies the search path to the Cable Router installation files.
The Capital add-on
After the Capital application is installed and its installation path is configured, selecting the Capital tool option accesses to the add-on.
Close
The Capital add-on activates the Capital Wiring Integrator (CWI) and displays its interface commands inside Electrical Routed System Designer. It also enables the Designcenter and the Capital Wiring Designer applications to communicate with each other. All user interface capabilities present in the CWI dialogs will be functional inside Designcenter and reflect the user interface actions as though they originate from the Designcenter application itself.
Capital tab on the Ribbon bar
When the Capital add-on is activated, the Capital tab with its four commands appear on the Ribbon bar.
Close
The command dialogs open in the Capital Navigator tab on the Designcenter resource bar.
Close
This command opens the Open Project dialog box.
Close
Here you can easily locate and open the required project data from the Capital database.
Close
What's new in NX Manufactiring
Dragging files into NX X Manufacturing Viewer
You can now directly drag an .nxmv file into the graphics window of the NX X Manufacturing Viewer, so you can open them quickly and easily. You can continue to open them using the Open File command.
Sorting tool list in the Tool Parameter Report
In NX X Manufacturing Viewer, you can now sort the tool list by Tool Number in the Tool Parameter Report. In the Table format of the Tool Parameter Report , you can arrange the Tool Number sequentially by using the Sort Ascending option or the Sort Descending option. To restore the Tool Number list to its default order, click No Sorting.
Displaying UDE parameters in the Tool Parameter Report
The user-defined events (UDE) parameters of the manufacturing part are now displayed in the Tool Parameter Report in NX X Manufacturing Viewer. In the Tool Parameter Report , the UDE parameters are listed in the UDE column.
Shortest tool length
The Operation Parameter Report now displays the shortest tool length value, as specified in NX Manufacturing. In the NX X Manufacturing Viewer application, you can view the shortest tool length values of the part or assembly in the Shortest Tool Length column of the Operation Parameter Report
Measure command enhancements
The Measure command in NX X Manufacturing Viewer now shows three decimal places for parts measured in millimeters, and four decimal places for those measured in inches. When creating a manufacturing part in NX Manufacturing, you can set the unit to either inches or millimeters. The Measure command uses the same measuring unit system that is used in NX Manufacturing, for calculating any object.
Searching for operations in the Program Order View
You can now easily find operations listed in the Program Order View of the Operation Navigator in NX X Manufacturing Viewer.The search box lets you search for operations easily and quickly. This simplifies navigation and improves efficiency.
Close
Bounding box enhancements
You can now view the bounding box with its dimensions for each individual manufacturing operation listed in the Operation Navigator. Earlier, the bounding box was displayed only for the program group. Now when you select a program group or an operation and click Display Bounding Box , the bounding box, along with its dimensions, is displayed in the graphics window of NX X Manufacturing Viewer.
http://peeplink.in/d13d9c324d40
Designcenteris the new name for Siemens' portfolio of mechanical design software. It goes beyond branding-the new moniker comes with increasing interoperability and "aggressive" new pricing that Siemens believes will serve everyone from a single-person design startup to a major enterprise OEM. Siemens NX and Siemens Solid Edge aren't going anywhere-yet. Both products exist as part of the Designcenter portfolio. Siemens hasn't announced any specific plans to phase out those brands, but most likely at some point, Designcenter will be the name of Siemens' CAD software.
Designcenter NXis a powerful software suite used for product design, engineering, and manufacturing. As technology evolves, various versions of Siemens NX, including the latest NX version, have been released, each with improved features and capabilities. Understanding the key versions of Siemens NX is crucial for professionals in design and engineering fields. The major releases typically include significant enhancements that improve usability and performance. Each NX version is designed to enhance user experience and streamline workflows, making it vital for professionals to stay updated on the latest features and improvements introduced in each NX version. Understanding the capabilities of each NX version allows users to fully leverage the software's potential in their design and engineering tasks. For those seeking to improve their understanding of the software, reviewing the unique characteristics of each NX version can be invaluable. This knowledge empowers users to select the most appropriate NX version for their specific projects and tasks.
What's New in NX 2512 - Axial Layout
Brand new in Designcenter NX 2512 there is now an Axial Pattern Layout option in the Pattern commands!  This will enable the quick creation of cylindrical or conical patterns for your designs, and can be measured within the tool either along the Angle or along the Axis for an easily detailed pattern.
Siemens Digital Industries Softwareis a global leader in the growing field of product lifecycle management (PLM), manufacturing operations management (MOM), and electronic design automation (EDA) software, hardware, and services.
2ytlt.Siemens-DesignCenter-NX-2512-3002-NX-2512-Series.part1.rar.html
2ytlt.Siemens-DesignCenter-NX-2512-3002-NX-2512-Series.part2.rar.html
2ytlt.Siemens-DesignCenter-NX-2512-3002-NX-2512-Series.part3.rar.html
2ytlt.Siemens-DesignCenter-NX-2512-3002-NX-2512-Series.part4.rar.html
2ytlt.Siemens-DesignCenter-NX-2512-3002-NX-2512-Series.part5.rar.html
2ytlt.Siemens-DesignCenter-NX-2512-3002-NX-2512-Series.part6.rar.html
2ytlt.Siemens-DesignCenter-NX-2512-3002-NX-2512-Series.part7.rar.html
