06 de Abril de 2026, 19:16 *
Autor Tema: Apulsoft Opalize v1.1.0  (Leído 79 veces)
« : 15 de Enero de 2026, 12:47 »
Free Download Apulsoft Opalize v1.1.0 | 4.8 Mb
When applying saturation or distortion to an audio signal, we often do so to add harmonics - to make basslines more audible on small speakers, add punch to drums, or help synths and instruments cut through the mix. In short: We want to sculpt the harmonic content of our sounds precisely - without introducing obvious, unpleasant distortion.
Meet Opalize - Harmonics Beyond Dynamics.
Opalize is not a basic waveshaper. It lets you create the harmonics you want - wherever you want them - while preserving the integrity of your original signal. Add the second through fifth harmonics to any frequency range you choose. And yes - independently of input level, if you prefer. Opalize gives you harmonic control with a level of precision that has never been available before.
Opalize works best with monophonic or bandpassed signals - but still delivers compelling results on broadband material. It includes low-pass and band-pass filters to help isolate fundamental tones for optimal harmonic shaping. One band can track the pitch of a monophonic input and automatically adjust a low-pass filter in real time.
Opalize's core DSP algorithm was developed by J. Budweiser. This plugin version was engineered by apulSoft.
Main Features
* Innovative harmonics generation with adjustable dynamics-independence.
* Add 2nd, 3rd, 4th & 5th harmonics to any signal.
* Generate even-order harmonics without DC-offset issues.
* Process up to 4 parallel frequency bands simultaneously.
* One band can follow the monophonic fundamental frequency.
* Smooth frequency analyzer display shows how harmonics are stacked per frequency.
* Minimal latency and phase-matched processing modes.
* Intuitive creation and editing of frequency bands directly on the analyzer display.
* Unlimited undo/redo for all actions.
* Built-in system-wide preset management with import and export of preset files, compatible across platforms and hosts using a human-readable xml file format.
* Plugin formats: AudioUnits/AAX/VST3 on macOS and Windows 64bit.
https://www.apulsoft.ch/opalize/
mof18.Apulsoft.Opalize.v1.1.0.rar.html
AlfaFile
https://alfafile.net/file/AdHDJ/mof18.Apulsoft.Opalize.v1.1.0.rar
