07 de Abril de 2026, 05:38 *
Autor Tema: WinTools.net Professional / Premium / Classic 26.1.1 Multilingual  (Leído 72 veces)
« : 18 de Enero de 2026, 12:31 »
Free Download WinTools.net Professional / Premium / Classic 26.1.1 Multilingual Fast Links | 7.3 MB
WinTools.net is a powerful all-in-one system optimization suite designed to improve performance, stability, and privacy on Microsoft Windows operating systems. It helps users clean unwanted files, remove invalid registry entries, manage startup programs, and fine-tune system settings for maximum efficiency.
With WinTools.net, you gain full control over Windows startup processes, memory usage, desktop customization, and network performance. The software also focuses on protecting your privacy by securely removing sensitive data and preventing unwanted system tracking.
WinTools.net Premium includes the following tools:
Clean Uninstaller
Safely removes installed software while monitoring changes made to the hard drive, Windows registry, and system files during installation.
Scan Files
Cleans junk, obsolete files, and dead references left behind by software, helping to reduce disk access time and improve performance.
Scan Shortcuts
Removes broken and unused shortcuts from Desktop, Start Menu, Application Data, and hard drives.
Scan Registry
Cleans invalid and unused registry entries that slow down system performance and increase boot time.
Startup Manager
Allows you to add, remove, enable, or disable startup items and control applications loaded during system startup.
Tweak UI
Provides advanced system, security, and user interface tweaks not available in standard Windows settings.
Net Tweaker
Improves network speed and connection stability by modifying hidden network parameters.
(Available in Professional edition only)
Your Privacy
A set of privacy protection tools that secure sensitive personal information.
Invisible Man
Prevents Windows from storing private data and allows later restoration when needed.
File Shredder
Securely deletes files, folders, and programs with no possibility of recovery.
IE Favorites
Quickly delete, backup, and restore Internet Explorer favorites and remove broken links.
RAM Memory Booster
Monitors and optimizes RAM usage to improve system performance and free memory for active processes.
Operating System:
Windows 11 / 10 / 8.1 / 8 / 7 / Vista / XP / 2008 / 2003 / 2000
Home Page:
http://www.wintools.net/
37m18.WinTools.net.Professional..Premium..Classic.26.1.1.Multilingual.rar.html
