07 de Abril de 2026, 19:57 *
Autor Tema: GiliSoft USB Lock 11.0 Multilingual  (Leído 43 veces)
« : 19 de Enero de 2026, 11:37 »
Free Download GiliSoft USB Lock 11.0 Multilingual Fast Links | 10.8 Mb
GiliSoft USB Lock is a data leak prevention tool that prevents leakage and copy of your data to USB Drives, External Drives, CDs/DVDs or other such portable devices. Once installed, USB Lock lets you block all such drives and devices that do not belong to you. With USB Lock, you can share your PC with anyone without fear of data theft.This is an easy USB Secure Software and powerful Endpoint DLP Suite that helps you to lock usb port,make dvd/cd burner read-only,block some websites,forbid some programs and disable more devices.
Block USB Drives:
Disable reading from USB disks or disable writing to USB disks.USB Lock doesn't allow any type of USB drive to access your computer unless you authorize it. By default, all types of USB drives are blocked including external drives, FireWire, Enhanced mini-USB, Host Controller Interface (HCI), HP-IL, Com, LPT, IrDA, USB on-the-go, U3, EHCI, RAID Controller, Host adapter, Serial Cable (use with data transfer), Serial ATA, ACCESS.bus and any storage device that is attached to USB port showing a drive in the system.
CD Lock,Block Media & Blu-ray Discs:
Disable reading from DVD/CD discs or making DVD/CD burner read-only.The application also blocks any disc that uses the disk hub, bay, combo or CD/DVD drive and allots a drive letter, for example; CD-R, CD-RW, CD-RAM, DVD-R, DVD-RW, DVD-RAM, HD-R, HD-RW, HD-RAM, Blu Ray-R, Blu Ray-RW, Blu Ray-RAM, Floppy Disk A, Floppy Disk B and Zip Drives.
Website Lock
Block accessing some websites. This utility allows you to block unwanted websites from display in Internet Explorer. If a website is blocked the user is forwarded to a blank page or to a "blocked page" and the contents of the original page are not loaded on your PC. Stop loading banners and ads, stop your kids from spending hours in chat rooms or remove undesired websites from their view. Prevent your children from having access to certain websites content such as adult sites and gambling.
Programs Lock
Block running any programs, including IE, Outlook, AOL, AIM, and more. You can even lock your control panel with one button click. Other features include the ability to choose your own message to display if anyone attempts to run one of your locked programs, and also includes password protection so only you can unlock the program when you are ready to use it. Allows the entire computer to remain active and running, and it only locks and prevents access to the programs that you specify. Easy to use interface shows you current status of all locked programs, and allows you to easily click and unlock as you wish
Devices Lock:
The program can be used to restrict read or write access to removable media devices such as CD, DVD, floppy, flash and USB drives.It also can be used to disable printer,moderm,com lpt ports,infrared,bluetooth,1394 ports.
Alarm Notification :
If user enters wrong password more than 5 times,it will send alarm notifications to your e-mail .
Copy Protection:
The program uses an advanced level of data leak prevention technology that does not permit duplication of your important files and copyright material to any USB drive or other such storage devices without your permission. The program works by blocking all types of unauthorized storage devices like USB drives, external drives, CDs, DVDs, etc., in this way it prevents plagiarism, piracy, illegal distribution and copying of your data
Data Leak Prevention:
USB Lock is a data leak prevention software. It prevents your data from getting leaked out to USB drives and other such storage devices by letting you control which device can access your computer while blocking all other unauthorized devices that do not belong to you. With USB Lock installed on your computer, you can feel safe that your data will remain on your PC safe and secure.
Operating System:Windows 2000/2003/XP/7/8/10/11
Home Page-http://www.gilisoft.com/
Visit All My News
86ijg.GiliSoft.USB.Lock.11.0.Multilingual.rar.html
https://turbobit.net/ysgjt9fwldlx/86ijg.GiliSoft.USB.Lock.11.0.Multilingual.rar.html
