06 de Abril de 2026, 22:07 *
Autor Tema: Gilisoft SnapID 8.7  (Leído 36 veces)
« : 19 de Enero de 2026, 15:48 »
Free Download Gilisoft SnapID 8.7 | 422.1 Mb
Gilisoft SnapID offers a wide range of features to help you enhance and transform your images. With Gilisoft SnapID, you can easily crop, resize, and rotate images to get the perfect composition. The software also allows you to adjust colors, brightness, contrast, and saturation to bring out the best in your photos.
One of the standout features of Gilisoft SnapID is its ability to add filters and effects. You can choose from a variety of presets or customize your own to create unique and artistic looks. Whether you want to give your image a vintage feel, add a dramatic glow, or create a surreal effect, this software has you covered.
In addition to basic editing functions, Gilisoft SnapID also provides advanced tools for more complex tasks. You can remove unwanted objects from images, retouch portraits, and even create collages. The intuitive interface makes it easy for both beginners and experienced users to navigate and use the software effectively.
Whether you are a professional photographer or just someone who loves to edit images for fun, Gilisoft SnapID is a great choice. It offers a comprehensive set of tools and features to help you unleash your creativity and transform your images into masterpieces.
Exclusive Features of Gilisoft SnapID
Advanced cropping tool
Allows you to precisely cut out specific areas of an image, enabling you to focus on the most important elements and remove unwanted parts. You can choose from various preset aspect ratios or customize the crop dimensions to suit your specific needs.
Resizing with precision
Easily adjust the size of your images without sacrificing quality. Whether you need to make an image smaller for web use or enlarge it for printing, this feature provides smooth and accurate resizing options.
Rotation and flipping
Rotate images to the desired angle or flip them horizontally or vertically for creative effects or to correct orientation issues. This gives you full control over the positioning of your images.
Color correction and enhancement
Fine-tune the colors in your images with a comprehensive set of tools. Adjust hue, saturation, and brightness to bring out the true beauty of your photos. Correct color casts and enhance contrast for more vivid and impactful images.
Brightness and contrast adjustment
Converting images to PDF format can integrate multiple images into one file, which is convenient for saving, sharing, and printing. This makes it easier to manage and view images, while also retaining the original quality of the images.
Saturation control
Boost or reduce the saturation of colors to create different moods and atmospheres. High saturation can make colors pop and appear more vibrant, while low saturation can give a more subdued and elegant look.
Filters and effects galore
Choose from a wide range of filters and effects to add a creative touch to your images. From vintage looks to modern artistic styles, there are options for every taste. Experiment with different combinations to achieve unique results.
Object removal made easy
Remove unwanted objects from your images with a seamless object removal tool. Whether it's a stray object in the background or a blemish on a subject, this feature allows you to clean up your images effortlessly.
Portrait retouching for perfection
Enhance portraits with tools specifically designed for retouching. Smooth skin, whiten teeth, and brighten eyes to create flawless portraits. Adjust facial features and remove imperfections for professional-looking results.
Collage creation wizard
Combine multiple images into a single collage with ease. Select from various layouts and templates, and customize the arrangement and size of each image. Add borders, shadows, and other effects to make your collages truly unique.
Batch processing for efficiency
Process multiple images at once with batch processing capabilities. Apply the same edits to a group of images, saving you time and effort. This is especially useful for photographers and designers who need to edit large numbers of images quickly.
Text addition and customization
Add text to your images for captions, labels, or artistic purposes. Choose from a variety of fonts, sizes, and colors, and customize the text's opacity, shadow, and outline. Position the text anywhere on the image for maximum impact.
Layers and blending modes
Work with layers to create complex compositions. Use blending modes to combine layers in different ways, adding depth and creativity to your images. Adjust the opacity of layers for seamless integration.
Histogram display for accurate analysis
View the histogram of an image to analyze its tonal distribution. This helps you identify areas that may need adjustment and make informed decisions about color and brightness corrections.
Zoom and pan for detailed work
Zoom in on specific areas of an image for detailed editing. Pan around the image to easily access different parts. This allows you to work with precision and ensure every detail is perfect.
Undo and redo functionality
Don't worry about making mistakes. The software offers unlimited undo and redo options, so you can easily go back and forth in your editing process until you achieve the desired result.
Save in multiple formats
Save your edited images in a variety of formats, including JPEG, PNG, TIFF, and more. Choose the format that best suits your needs, whether it's for web use, printing, or sharing on social media.
User-friendly interface
The intuitive and user-friendly interface makes it easy for both beginners and experienced users to navigate and use the software. With clear menus and tooltips, you can quickly find the features you need and start editing your images right away.
https://www.gilisoft.com/snapid.htm
7bcwo.Gilisoft.SnapID.8.7.rar.html
https://turbobit.net/w97zeghcbcg8/7bcwo.Gilisoft.SnapID.8.7.rar.html
