06 de Abril de 2026, 13:01 *
Autor Tema: Siemens Solid Edge 2025 MP0012  (Leído 65 veces)
« : 21 de Enero de 2026, 02:49 »
Free Download Siemens Solid Edge 2025 MP0012 | 510.4 mb
Languages Supported: 中文 (Simplified), 中文 (Traditional), Čeština, English, Français, Deutsch,
Magyar, Italiano, 日本語, 한국어, Polski, Português-Brazilian, Русский, Español
Siemens Digital Industrieshas releasedSolid Edge 2025 Update 12 (MP0012)is an integrated set of powerful, comprehensive, and accessible tools that advance all aspects of the product development process.
Solid Edge 2025 introduces Solid Edge X, Solid Edge software in a secure SaaS environment, with new Artificial Intelligence (AI) tools to help you work smarter. Solid Edge 2025 also includes a range of enhancements to increase modeling speed, improved etch and bend features for sheet metal design, and simplified Model-based definition (MBD) creation. Expand your innovation toolkit with access to advanced capabilities on demand with token licensing bundles and take advantage of seamless integration with industry-leading solutions across the Siemens Xcelerator portfolio. Solid Edge, which is part of the Siemens Xcelerator portfolio, the comprehensive and integrated portfolio of software, hardware and services, provides you with an innovative and comprehensive approach to product development for the mainstream market.
Solid Edge 2025 Update 12 (Version: 225.00.12.04) Release Notes - Date: January 13, 2026
This Solid Edge Update resolves the following PRs:
===Licensing===
PR 11353599: When signing in on a second device, Solid Edge X will not run after clicking Yes to transfer the session.
PR 11381883: Licensing tool not working on Solid Edge 2025 Update 11.
===Part/Profile/Sheetmetal===
PR 11386524: While working on a Solid Edge file, it becomes read-only and cannot be saved.
PR 11361932: The 'Wrap Sketch' result shows an unexpected offset if the line crosses a tangent edge.
PR 11374370: Solid Edge crashes when opening dwg as a part sketch.
PR 11380674: A file containing Thai characters in the Text profile cannot be opened.
PR 11382066: The position is wrong when adding the feature from the feature library.
PR 11384393: The Wrap Sketch function works on cylindrical surfaces but not on rectangular shapes.
===Assembly===
PR 11340243: An error has occurred due to physical motion.
PR 11015846: A Part family can't be replaced with a copy in Assembly.
PR 11356035: A hole from an assembly feature goes to a bad state after the file is saved.
PR 11357456: Unable to link variable from top assembly to peer assembly.
PR 11370870: The adjustable part length is not correct when switching the FOA member.
PR 11372397: Assembly hole features fail during edit or recompute.
PR 11378739: Zoom-to does not go to the zone where the cursor is located.
PR 11351177: Face is not selectable for applying a center plane relationship.
PR 11374324: After inserting a pattern using any frame member, the components intermittently become invisible.
===Draft===
PR 11356069: DFT- Callouts are not displayed correctly when Solid Edge 2023 draft files are opened in 2025.
PR 11374142: Solid Edge aborts if we delete a block connected by an intersection relationship.
===SEEC===
PR 11347590: Solid Edge crashed when replacing an assembly.
PR 11364877: After a Save, the newly named reference contains text from the original file.
PR 11365479: Assembly upload/check-in takes a long time.
PR 11375872: The suppress command in Solid Edge is deleting the file from the TC BOM.
PR 11378164: Solid Edge crashed while changing the access group.
PR 11378514: Solid Edge templates will not upload to Teamcenter.
PR 11384861: Update models in assembly while working in SEEC; the assembly links break.
PR 11380437: Need the TechPub integration for Teamcenter.
===Translators===
PR 11357087: Solid Edge closes when exporting DWG
PR 11365619: Wrong dimension value exported to .dwg. Seems to be an issue with rounding.
PR 11375968: IGES file import is incomplete.
Enabled the ability to open NX 2512 Files in Solid Edge 2026.
Solid Edgefrom Siemens Digital Industries Software is one of the most widely used 3D CAD systems worldwide. Solid Edge is powered by Siemens' Parasolid software - the most widely used computer-based geometric modeling kernel in the industry. Based on this, Solid Edge and its add-ons are continuously being developed and are therefore always up to date. Solid Edge offers a complete product development portfolio. With its unique combination of sequential modeling and synchronous technology, it is the perfect solution for modern product design. The technology combines the speed and simplicity of direct modeling with the flexibility and control options of parametric design.
Introducing Solid Edge 2025: Innovate without limits
Siemens Digital Industries (DI)is an innovation leader in automation and digitalization. Closely collaborating with partners and customers, DI drives the digital transformation in the process and discrete industries. With its Digital Enterprise portfolio, DI provides companies of all sizes with an end-to-end set of products, solutions and services to integrate and digitalize the entire value chain. Optimized for the specific needs of each industry, DI's unique portfolio supports customers to achieve greater productivity and flexibility. DI is constantly adding innovations to its portfolio to integrate cutting-edge future technologies. Siemens Digital Industries has its global headquarters in Nuremberg, Germany, and has around 75,000 employees internationally.
Owner:Siemens Digital Industries Software
Product Name:Solid Edge
Version:2025 Update 12 (MP0012) build 225.00.12.04
Supported Architectures:x64
Website Home Page :
https://solidedge.siemens.com/
System Requirements:Windows *
Software Prerequisites:pre-installed Siemens Solid Edge 2025.2410 and above
xSiemens Solid Edge 2025 MP0012
Close
Added by 3% of the overall size of the archive of information for the restoration
Close
iemka.Siemens.Solid.Edge.2025.MP0012.rar.html
https://turbobit.net/8xf57vzausld/iemka.Siemens.Solid.Edge.2025.MP0012.rar.html
