04 de Abril de 2026, 16:46 *
Autor Tema: UltFone Windows Data Recovery 10.7.0.16  (Leído 66 veces)
Conectado Conectado
« : 21 de Enero de 2026, 02:49 »
Free Download UltFone Windows Data Recovery 10.7.0.16 | 157.2 Mb
Employing a structured data backup scheme is a good approach for ensuring your digital information's safety in the long run. However, when things do become eventful and accidents and mishaps that involve data loss do occur, users find themselves lacking access to their favorite files, and in need of a solution. UltFone Windows Data Recovery is here to address such issues, by offering users a scanner that will automatically detect lost data, offer multiple recovery options and filtering.
Select entire drives, or, if required, any particular locations for the scanning process and you're good to go
The application will allow users an easy selection for the drives where the scanning is about to be performed, but only single drives are supported for each process, and the same is valid for when selecting other locations.
Speaking about locations, in case users already know the location of the files in question, the app allows for individual selection of directories, as well as common locations, such as one's desktop area or, the recycle bin, which are offered as pre-defined choices.
Support for multiple file types, combined with filtering and search features, make for an easier job
Continuing the streak of flexibility on offer, UltFone Windows Data Recovery also allows one to select the actual file types that are to be accounted for in the search process, with some of the most commonly used formats as pre-defined options.
Prior to the scanning process, one will be able to apply a wide range of filters, as well as perform searches using the built-in features, which can help narrow-down results and make the entire process more efficient.
Straightforward recovery software, which has its emphasis revolving around flexibility in terms of scanning location and file types. This application addresses those who require a simple tool for scanning for lost files and recovering them in just a few simple steps.
https://www.ultfone.com/windows-data-recovery.html
ytcab.UltFone.Windows.Data.Recovery.10.7.0.16.7z.html
https://turbobit.net/2astbinkmthl/ytcab.UltFone.Windows.Data.Recovery.10.7.0.16.7z.html
