05 de Abril de 2026, 18:23 *
Autor Tema: apulSoft apUnmask v1.0.6  (Leído 51 veces)
« : 24 de Enero de 2026, 03:37 »
Free Download apulSoft apUnmask v1.0.6 | 10.9 Mb
apulSoft apUnmask is an audio plugin to amplify components of the audio that are psychoacoustically masked by other components.
To achieve this, apUnmask uses parts of the detector algorithm of the opus high-quality audio compression codec. Signal components that would get removed by compression are extracted. These can normally not be heard as they are masked by louder components in time and frequency. apUnmask enables amplifying and sculpting the masked content and adding it to the music.
To shape the frequencies of the extracted signal, it is fed through a linear phase graphical equalizer. It features a bezier curve smoothed frequency response without overshoot.
The result is a form of hyperrealistic audio. The process helps the listener to hear more aspects of the music at the same time. apUnmask can be used as a mastering effect or as an intelligent exciter for single instruments.
Features
Demo version! Download and try in demo mode.
Use to power of audio compression algorithms to uncover unheard parts of your music.
Linear phase delta signal equalization with graphical editing of the frequency response.
Delta listen button: check what would be removed by compression.
3128 samples latency (44.1kHz)
Unlimited undo/redo for all actions.
Plugin formats: AudioUnits/AAX/VST/VST3 on macOS and Windows
Built-in system-wide preset management with import and export of preset files, compatible across platforms and hosts using a human-readable xml file format.
Bright & dark color schemes and support for user defined color schemes.
https://apulsoft.ch/
Rapidgator-->Click Link PeepLink Below Here Contains Rapidgator
http://peeplink.in/d6d00b4088c6
Password: 123
bqagc.apulSoft.apUnmask.v1.0.6.rar
AlfaFile
https://alfafile.net/file/Ad3uJ/bqagc.apulSoft.apUnmask.v1.0.6.rar
https://turbobit.net/058qbwc4e09l/bqagc.apulSoft.apUnmask.v1.0.6.rar.html
