Free Download proDAD Hide 2.0.218.1 (x64) Multilingual Fast Links | 200 MBHide can do magic - all done automatically within the shortest time without any manual effort! Hide is an ideal tool equally suited for professional and holiday shooters, for YouTubers as well as sophisticated cinematographers. Hide is a true problem remover whenever something gets into your frame that might either distract the viewer or simply does not belong there. Most of the time those glitches become evident during editing - when there is no chance anymore for a second take.
How often in the past have you been upset about ruined recordings because a person has been walking through your picture or other disturbing objects have gotten in the view. With Hide you render the disturbing object invisible which helps you saving unrepeatable moments and precious memories.
Hide can truly do magic.
First you mark the unwanted object by applying the intelligent automatic tracking mode. After an analyzing process Hide will substitute the object by its original background - all done automatically within the shortest time without any manual effort. For this process Hide will need some seconds of footage before and after the object to be removed has gotten out of view.
Features:
- Compared to a conventional and rather imperfect clone stamp and other time and work intensive substitution methods as featured in an NLE program, Hide's innovative technology offers the far better quality within a fraction of the time.
- By attaching optional USB input devices, the workflow can even be further enhanced. While controlling the tracking direction and speed with your optional pedals you simultaneously follow the process with your mouse and keyboard for an optimal tracking result even with complex objects.
- The unparalleled high-quality result driven by the newest Hide technology will amaze you and your viewers.
Highlighted Features:
- Clear timeline for a fast workflow
- Easy trimming of clips
- Comfortable marking of objects
- Manual & automatic object tracking
- Comprehensive keyframe support
- Supporting optional input devices (like USB pedals)
- Effects preview window prior to file export
- Direct YouTube upload if desired
- Compatible with every framerate (24p/25p/30p/50p/60p and more)
- Supports resolutions up to (and including) 8K
System Requirements:- Windows Vista, 7, 8, 8.1, 10, 11 (64-bit)
- 2GB main memory, recommended: i7 CPU, 6GB main memory.
Home Page -Buy Premium From My Links To Get Resumable Support,Max Speed & Support MeRapidgatorr58i3.proDAD.Hide.2.0.218.1.rar.htmlDDownloadr58i3.proDAD.Hide.2.0.218.1.rarhttps://turbobit.net/p6u6qwbcsgv8/r58i3.proDAD.Hide.2.0.218.1.rar.htmlLinks are Interchangeable - No Password - Single Extraction
