04 de Abril de 2026, 23:55 *
Autor Tema: O&O Defrag Professional Server 30.5.1214 (x64)  (Leído 40 veces)
« : 28 de Enero de 2026, 05:42 »
Free Download O&O Defrag Professional / Server 30.5.1214 (x64) | 68.1 Mb
Your PC will become slower over time. Fragmentation occurs on every computer. When files are saved, they are chopped up and stored in individual pieces on the hard drive or SSD wherever there is space. Defragmentation reverses this storage chaos. A defragmentation re-sorts the saved files and puts them back together.
How does O&O Defrag help?
O&O Defrag cleans up this shoebox by combining the snippets of a file and writing them one after the other to the hard drive or SSD. In addition, the files are reorganized so that access times when loading are minimized. This saves you time and protects your data storage media. If you use O&O Defrag regularly, the access speed and overall performance of your Windows system will noticeably increase. And so that you never have to worry about "file snippets" again, O&O Defrag can also run completely automatically in the background.
Simply simple
Everyone should have a fast computer. That's why we made O&O Defrag 30 so simple that anyone can use it. The new modern view does not require complicated settings.
No difficult decision as to which is the best defragmentation strategy for your PC. O&O Defrag takes care of everything itself. All you have to do is choose whether you want to start O&O Defrag yourself manually or whether you want it to take care of everything automatically.
New: O&O VisualDisk:
Visualization of write accesses to SSDs
O&O VisualDisk clearly displays write accesses to the hard drive, such as those that occur on flash-based storage media such as SSDs and NVMe drives. This innovative function shows how defragmentation can help reduce future write accesses and extend the lifespan of SSDs. The user gets a clear picture of how the hard drive is working and how its performance can be optimized through targeted measures.
O&O VisualDisk helps you understand how O&O Defrag can get the most out of a hard drive and protect it from unnecessary wear and tear - for a long-lasting and fast PC system.
O&O StartupManager:
Remove unnecessary ballast at startup
The new O&O StartupManager offers a clear overview of all programs, tasks and services that are automatically executed when Windows starts. With detailed information about each program - including the impact on the system's startup time - it is easy to decide which programs should be activated or deactivated.
Unnecessary applications are marked as such and can be deactivated with a mouse click. Defective startup entries are also detected and can be deleted. This shortens the computer's startup time and ensures that it is ready for use more quickly.
New Boot-Time Optimization
and Improved O&O IntensiveOptimize
The new Boot-Time Optimization automatically optimizes your system before Windows starts, ensuring that even locked or critical system files can be thoroughly optimized for maximum performance.
With the enhanced O&O IntensiveOptimize, advanced users can further optimize their system in a dedicated Windows environment, with full access to all user and system files. Thanks to the improvements in version 30, setup now takes just a single click-even on BitLocker-encrypted drives.
My individual O&O Defrag
Of course, O&O Defrag 30 also gives you the opportunity to choose your own personal defragmentation strategy. In the classic view you can make all the professional settings yourself.
You can switch at any time in O&O Defrag 30 between the classic view with all professional settings and the modern view, which is reduced to the essentials.
System maintenance of your data carriers
O&O Defrag 30 checks your hard drive or SSD for inconsistencies that can lead to problems. The component memory and Windows system files are checked for errors.
Once the check has been completed, O&O Defrag will show you whether and which errors were found. Most errors can be corrected directly using the repair function.
Remove ballast and free up storage space
Over time, more and more ballast accumulates on a PC. Temporary files, Internet cache and the like can take on considerable proportions. This can lead to a storage space problem, especially on modern SSDs. But backups also take much longer than actually necessary.
With the improved O&O DiskCleaner in O&O Defrag you can put an end to files you no longer need.
Remove unnecessary programs
Programs that are no longer used can pose a security risk. Definitely they are wasting storage space. You probably won't need a 2011 tax return program anymore. But do you even know it's still installed?
O&O Defrag 30 now clearly shows you all installed programs. And with one click you can easily uninstall what you no longer need. This saves storage space (important for SSDs) and increases your security.
Automatic defragmentation in the background
Automatic defragmentation optimizes your data storage media in the background without negatively affecting your computer's performance. O&O Defrag can be set so that defragmentation starts automatically at a certain level of fragmentation, on certain days of the week, or whenever your screen saver is active.
Native support for the ARM platform
For the first time, O&O Defrag 30 now supports the family of CPUs based on the ARM architecture (Advanced RISC Machine) in addition to the existing Intel and AMD processors. These are currently mainly used in new Windows PCs with AI support and will take up a significant market share in the coming period due to their energy efficiency and lower costs.
Product highlights
"Install & That's All": After installation, no further settings need to be made; the program selects the defragmentation method that is suitable for the system and applies it.
SOLID/Quick: This method, developed specifically for SSDs, performs a superficial optimization of the SSD, for example by deleting the free storage space. This method is gentler and faster.
SOLID/Complete: This method, developed specifically for SSDs, is used to thoroughly optimize the SSD.
ClusterView for SSDs: In order to show the degree of fragmentation of an SSD, the ClusterView now shows the logical structure of an SSD, correspondingly 6 blocks are combined into one
O&O DiskCleaner - Searches and removes temporary and unnecessary files that consume disk space and increase fragmentation
Fragment filter to identify the most fragmented files on a drive
Optimization of systems with thin provisioning
Time history shows which defragmentation action led to which optimization success
Easy to use - suitable for beginners to professionals
Even faster system and program starts
Duration of defragmentations reduced
Defragmentation of locked files
Check&Repair: Checking and repairing a recovery environment
O&O IntensiveOptimize: Bitlocker support
O&O StartupManager: Remove unnecessary ballast at startup
O&O VisualDisk: Visualization of write accesses to SSDs
Efficiently prevents renewed fragmentation
Extends the lifespan of the hardware
Faster internet surfing
Increases the chance of recovering lost data
Speeds up backup and restore operations
Defragmentation of your PC at the push of a button
Supports Windows 11 and 10 (64-bit)
System Requirements:supports 64 bit versions of Windows 11 und Windows 10
https://www.oo-software.com/
16zc2.OO.Defrag.Professional..Server.30.5.1214.x64.rar.html
https://turbobit.net/2b8a3bwl2rn7/16zc2.OO.Defrag.Professional..Server.30.5.1214.x64.rar.html
