05 de Abril de 2026, 14:11 *
Autor Tema: Carve Audio Slapshot v1.0.4  (Leído 38 veces)
« : 03 de Febrero de 2026, 10:49 »
Free Download Carve Audio Slapshot v1.0.4 | 16.3 Mb
Slapshot is a slap delay designed to add instant depth, width, and character, without the mud that often comes with reverb. With built-in processing under the hood, it keeps the effect clean, controlled, and easy to blend, making your tracks sound polished in seconds.
Add Depth and Width Without Muddying Your Mix
Use this space for detailed information or context
What Is Slapshot?
Slapshot is a slap delay plugin by Carve Audio, designed to add depth, width, and character while staying clean and controlled in a mix.
Reverbs and delays are great at creating space, but they often introduce muddiness unless you follow them with additional tools like EQ, de-essing, compression, or modulation. Slapshot takes care of that work for you. It's built around slap delay to create the perception of space, while additional processing under the hood keeps the effect smooth, focused, and easy to blend with the dry signal.
The result is a bigger, more dimensional sound that still feels tight, clear, and polished, without long effect chains or endless tweaking.
Slapshot works especially well on vocals, guitars, and keys, but it can be used anywhere you want depth without losing impact.
Features
Here's what to expect
Slap Delay Built for Mixing
Choose from stereo, mono, and BPM-synced slap modes, including left/right variations. This makes it easy to dial in anything from tight, focused slap to wider, tempo-locked effects.
Clean, Controlled Sound by Design
Tightness Control for Instant Results
Multiple Slap Modes for Flexibility
Built-In Tone Shaping
High-pass and low-pass filters shape what feeds into the delay, keeping low-end weight and harsh highs under control. This helps the effect stay clear, especially on vocals.
Character When You Want It
Optional LoFi and Drive controls add grit and attitude to the delayed signal, helping it sit behind the source or stand out when needed. You can even disable the delay entirely and use these for texture alone.
https://www.audioloom.com/carve-audio/slapshot
Uploady
mmer2.Carve.Audio.Slapshot.v1.0.4.rar
Rapidgator-->Click Link PeepLink Below Here Contains Rapidgator
http://peeplink.in/bc3f38a1a855
Password: 123
mmer2.Carve.Audio.Slapshot.v1.0.4.rar.html
https://turbobit.net/jn6c2kxdye2z/mmer2.Carve.Audio.Slapshot.v1.0.4.rar.html
FileServe
https://fileserve.com/7gi1nfdnu6hh/mmer2.Carve.Audio.Slapshot.v1.0.4.rar.html
