06 de Abril de 2026, 05:00 *
Autor Tema: Password Depot 19.0.3 Multilingual  (Leído 25 veces)
« : 10 de Febrero de 2026, 07:12 »
Free Download Password Depot 19.0.3 Multilingual Fast Links | 60 Mb
Password Depot is a powerful and very user-friendly password manager which helps to organize all of your passwords - but also, for instance, information from your credit cards or software licenses. The software provides security for your passwords - in three respects: It safely stores your passwords, guarantees a secure data use and helps you to create secure passwords. However, Password Depot does not only guarantee security: It also stand for convenient use, high customizability, marked flexibility in terms of interaction with other devices and, last but not least, extreme functional versatility.
Safe Password Storage
Best possible encryption. In Password Depot, your information is encrypted not merely once but in fact twice, thanks to the algorithm AES or Rijndael 256. In the US, this algorithm is approved for state documents of utmost secrecy!
Double protection. You can secure your passwords files twice. To start with, you select a master password that has to be entered in order to be able to open the file. Additionally, you can choose to protect your data by means of a key file that must be uploaded to open the file.
Protection against brute-force attacks. After every time the master Password (If need) entered incorrectly, the program is locked for three seconds. This renders attacks that rely on the sheer testing of possible passwords - so called "brute-force attacks" - virtually impossible.
Backup copies. Password Depot generates backup copies of your passwords files. The backups may be stored optionally on FTP servers on the Internet (also via SFTP) or on external hard drives. You can individually define the time interval between the backup copies' creation.
Secure Data Use
Protection from keylogging. All password fields within the program are internally protected against different types of interception of keystrokes (Key Logging). This disables that your sensible data entries can be spied out.
Traceless Memory. Dealing with your passwords, Password Depot does not leave any traces in your PC's working memory. Therefore, even a hacker sitting directly at your computer and searching through its memory dumps cannot find any passwords.
Clipboard protection. Password Depot automatically detects any active clipboard viewers and masks its changes to the keyboard; after performing auto-complete, all sensitive data is automatically cleared from the clipboard.
Virtual keyboard. The ultimate protection against keylogging. With this tool you can enter your master password or other confidential information without even touching the keyboard. Password Depot does not simulate keystrokes but instead uses an internal cache, so that they can neither be intercepted software- nor hardware-based.
Fake mouse cursors. Typing, using the program's virtual keyboard, you can also set the program to show multiple fake mouse cursors instead of your usual single cursor. This additionally makes it impossible to discern your keyboard activities.
Verified Passwords
Uncrackable passwords. he integrated Password Generator creates virtually uncrackable passwords for you. Thus in future, you will not have to use passwords such as "sweetheart" anymore, a password that may be cracked within minutes, but e.g. "g\/:1bmVuz/z7ewß5T$x_sb}@
Verified password quality. Let Password Depot check your passwords' quality and security! Intelligent algorithms will peruse your passwords and warn you against 'weak' passwords which you can subsequently replace with the help of the Passwords Generator.
Password policies. You can define basic security requirements that must be met by all passwords which are added or modified. For instance, you can specify the passwords' minimum length and the characters contained therein.
Security warnings. Password Depot contains a list of warnings which always keep an eye on your passwords' security. For instance, the program warns you in case you use the unsafe FTP protocol and in this case advices you to use SFTP instead.
Protection against dictionary attacks. An important warning featured in Password Depot is the notification in case you are using unsafe passwords. These are passwords which are frequently used, therefore appear in hacker dictionaries and are easily crackable.
Warning against password expiry. You can set Password Depot to warn you before your passwords expire, for instance before the expiry date of your credit card. This ensures that your password data always remains up-to-date and valid.
Operating system: Windows Vista, 7, 8, 10, 11 or higher
400 MHz Intel Pentium II processor or higher
At least 4 GB of RAM or more
At least 50 MB of free space on the hard disk
https://www.password-depot.de/en/index.htm
s1vt5.Password.Depot.19.0.3.Multilingual.rar.html
https://turbobit.net/d35v0md7efma/s1vt5.Password.Depot.19.0.3.Multilingual.rar.html
